Old 05-24-2005, 06:11 PM
tdag tdag is offline
code po401
2001 explorer, 4.0, check eng. light came on i pulled the code po401, egr, insufficient flow detected. what can i do to correct this problem. thanks
Old 05-24-2005, 07:57 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Sounds to me like the EGR valve is stuck because of carbon bulid up and needs to be cleaned. you could do it your self just clean it with break cleaner or something similar that dosen't leave a residue.
I disregard my perceived image in the persuit of knowledge.
Old 05-24-2005, 10:54 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: code po401
i use carb and choke cleaner, the EGR gasket may also need replaced.
