code po 401
2001 explorer, 4.0, check eng. light came on i pulled the code po401, egr, insufficient flow detected. what can i do to correct this problem. thanks
Re: code po 401
More than likely it is the DPFE (Delta Pressure Feedback EGR) valve. Ford has has a major problem with them.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: code po 401
People whom have had this problem have replaced the egr valve and the eger silinoid with no fix but they have round that for some reason the DPFE (Differential Pressure Feedback EGR) set this code to and have found this is a food fix.
This part number was for a sport trac have them reference it for your explorer PART NUMBER IS FMC 4U7Z9J460AA AFTER 11/01 BUILD DATE approx. $35.31 WITH TAX. DON'T BUY THE WELL'S VERSION, SAME AS THE ORIGINAL |
Re: code po 401
Provide the dealer parts counter person with year, model and engine type. Also, keep in mind that the egr sensor requires secure vacuum hoses. The Ford basic part number for egr sensor hoses is a 9P760. These hoses are silicone based and a regular vacuum hose will overheat and dry causing them to split. If it were me, I would change both hoses and the sensor itself. IMO |
Re: Re: code po 401
2001 model may have one vacuum hose. But, it still has a vacuum hose that should be closely examined. |
Re: code po 401
I have the same problem with my 02 trac code 401, Where is the egr located on the expolders?
Re: Re: code po 401
engine. The sensor should be black, the size of 4 crackers thick with a vacuum hose. I use the word cracker to refer to the squareness and thickness of common table saltine cracker. IMO |
Re: code po 401
I happened to replace my egr sensor and everything seems to be great, thanks alot for the help guys.
Re: code po 401
I have the same problem with my '02 Explorer Sport. It pulled up code PO401 and the check engine light came on. I called the dealer and was told there was a recall for the DPFE Sensor (Differential Pressure Feedback EGR). He needed the Vin number off of the car and ran a check on there computer. Sure enough it was recalled. They will replace for 50,000 milesor 5yrs. Great since the part costs $80.oo at AutoZone.
