2003 Concorde Engine Light and Shutdown
Recently the engine light came on and stayed on. I was low on gas and suddenly the engine shut off and would not start. Seemed like I was out of gas or had bad gas. After looking under the car and hood for a few minutes I tried starting the car again. It started right up. I went to the gas station, filled up, and put in some "dry gas". I also made sure the gas cap was on securely.
The light then went off and I had no problem. However, the light has since come on again and the engine has shut off even when the tank is almost full. A friend of mine thinks it may be the fuel pump. Any experience out there? I see others have reported an O2 sensor problem. Not sure what or where the O2 sensor is. UPDATE: I was able to run the diagnostic routine and get codes of P0340 and P0344. P0340 may indicate a camshaft sensor but I cannot find the P0344 code. UPDATE II: Here is a great site for learning about OBD-II which are standard set of diagnostics. http://autorepair.about.com/od/dianostictroublecodes/ Now the question is what makes the camshaft sensor go off? UPDATE III: Both codes have to do with the cam sensor. From everything I see it appears the first order of business is to replace the sensor. Anyone know where this is on a 2003 Concorde ? Back to Square 1: Replaced the sensor. The engine light still comes on. Any help? Last edited by yardboss; 05-27-2005 at 04:59 PM. |
O2 sensor should be on the exhaust...sorry i dont have a more definite answer on that.
As far as it shutting down, interesting on a 2-yr old vehicle. >>RQ<< |
