Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 05-24-2005, 03:57 PM
clariveros's Avatar
clariveros clariveros is offline
Shaking at 30-40 mph
Hello all,
My car is acting weird. Sometimes, it happens about twice a week. Sometimes I am driving between 30-40mph and the car starts shaking like there is no tomorrow. You know the wheel. When I turn off the car and get out of the car, it smells burned. What do you think it can be? Please help, 93 mx6 also just recently had the transmission tune up, and this started to happen after this was done, help?
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 05-31-2005, 11:49 AM
Arnolds97 Arnolds97 is offline
Trans
I take it is an Automatic? Does it do it at shifts or just cruising? If it is doing it at shifts then I hope your mechanic put enough fluid in the transmission. Torque Converter shudder? Pull your Trans Dipstick check the level and see if the fluid is dark brown to black and smells burnt. If it is, Not Good. These cars are also notorious for bad CV joints too. Check them. The Small could be from a leak onto your exhaust so check for that. Some times when you get a cahnge they may spill fluid on the engine and takes awhile to burn off.
Old 11-18-2005, 11:59 AM
agatehawk agatehawk is offline
Re: Shaking at 30-40 mph
Check your air intake hose, too. My car did what you're describing, and it turned out that the air intake hose had gotten some cracks in it. It was about a $70 part, and easy to replace.
Old 11-29-2005, 03:08 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Re: Shaking at 30-40 mph
I don't see how a crack in the intake hose would cause such extreme shaking.
Something you might want to check for is rotor warping, ABS sensor might be faulty ( if it has ABS ) and will cause the brake system to act bizarre on it's own, have the rims balanced and see if you have any rim/tire damage, Take it in for bearing inspection, alignment.
Theres too many things that can make that happen, just have to narrow it down.
