Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-24-2005, 03:56 PM
Eibon Eibon is offline
Hissing sound from heater/AC
Hi, last week I went to turn my heat off on my 86 Cutlass Ciera and it seemed 'stuck'... then a small brown plastic cylinder cracked and fell on the floor through the middle of the dash.
Ever since this happened I get a hissing sound every time I turn the engine on, and the fan is blowing AC through the top vent when I'm driving down the road. I can still control the AC with the switch, the fan works fine and is adjustable, the heat will come on if I move it over, etc... but this hissing is getting annoying.
Thank you.
Old 05-25-2005, 05:49 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Hissing sound from heater/AC
The heater/ac is controlled by vacuum. The hissing sound is a vacuum leak. I can't tell from your description what fell off but if you replace it or find the hose it was connected to and block it off with a golf tee the hissing should go away.
