Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-24-2005, 03:12 PM
Benag Benag is offline
dash light!
Does anyone know where to find a website that shows what all the lights around the speed and tach gauges mean? I have one that looks like a radiator with a little bit of fluid in the bottom, but my coolant is fine. Thanks.
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 05-26-2005, 05:28 AM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: dash light!
Look in the manual......
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 05-26-2005, 03:07 PM
Re: dash light!
I would if I had one. I'm ordering a Chilton book for it though. Thanks.
'95 Eclipse GS-T
5-Speed
Old 05-27-2005, 06:51 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: dash light!
The coolant light is for the level in the overflow bottle. Did you check there or in the radiator?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-28-2005, 12:12 AM
Re: dash light!
I checked the bottle. It is on the full line near the bottom. I think it was the back hatch washer fluid though, I found out it was empty so I filled it up and the light went away. But do you have any idea why my engine makes a weird ticking noise when the turbo spools up? I don't think it is coming from the turbo itself but I don't know. It only does it sometimes and only after I replaced the MAF sensor.
'95 Eclipse GS-T
5-Speed
