Old 05-24-2005, 02:13 PM
Kristi478 Kristi478 is offline
Car is Shaking
I have a 1998 V6 Mustang. My car started shaking while driving a few months ago. I have taken it to several different places and I feel like I am getting the run around. Over the past few months I have Had all rotors turned, new brakes put on the front, new struts on the front, front end aligned, all tires balanced twice, and just got a new tire. Of course the car is still shaking. It does not matter if I am driving fast or slow, but shakes more at faster speeds. I can feel it in the steering wheel, but also in the seats. I have a radar detector and it is constantly bouncing up and down. Any idea what the problem might be?
Old 05-24-2005, 03:08 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: Car is Shaking
your drivetrain might be shot...
Old 05-24-2005, 03:15 PM
drivetrain?
What does the drivetrain do?
Old 05-25-2005, 01:25 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Re: Car is Shaking
Thats helpful
It sounds like there is still a problem with your wheels, or tires. I would think that maybe one of your tires might have a bulge on it, from what you have described. It in now way has anything to do with your brakes. I normally will not turn my rotors, unless they are warped. Rotor turning is bad for two reasons; when you take material away it decreases its ability to stop the car because brakes act just like a heat sink, so the more material you have on your rotors, the better it will dissipate heat, and now it increases the rotors chance to wrap, because of said less material. FYI
You mentioned new tires already, damn
I can see why you are getting the run around, because it should have been fixed with everything you mentioned.
Have you had a friend drive next to you, to see if they can spot anything the car is doing, so you can narrow it down. You could swap tires around front to back, to see if it changes.
Its all shooting in the dark, until you can get some more info to us.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 05-25-2005, 01:52 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
How is your engine performing? Could it be a bad miss or a balancer issue. Maybe u-joints as well?
Also, you say you just got one tire?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-25-2005, 08:33 AM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
car shaking
Check the driveshaft...if it's bent even just a little, you'll definately feel it in the seats and steering wheel.....
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 05-25-2005, 10:09 AM
Re: Car is Shaking
The tires on the front are pretty new, but my back tires were older. I took the car to a repair shop and they said my back passenger tire was sepparated so I had it replaced. The back driverside tire is still ok. It feels like the shaking is coming from the front passenger side. That is the newest tire on the front, but it seems like the shaking started shortly after I had it put on. I had all tires looked at when I got the new one put on the back and they said there were no problems. This shaking is driving me crazy!!
Old 05-25-2005, 01:30 PM
just add boost just add boost is offline
Send a message via AIM to just add boost Send a message via MSN to just add boost
Re: Car is Shaking
That verry much sounds like a tire or U-Joint problem.
Old 05-25-2005, 02:06 PM
SkylineUSA's Avatar
Re: Car is Shaking
Its been a while since I had a u-joint go out, do you feel that in the steering wheel? If its front oriented, its has to be the front tires, that is why I suggest swapping the front to back and see what you get.
Old 05-25-2005, 03:05 PM
TheStang00's Avatar
Re: Car is Shaking
wheel bearing?
Old 05-26-2005, 06:26 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Car is Shaking
Could be a wheel bearing. I fixed a similair complaint for my friend's father in-law. His drivers side front wheel bearing was absolutely shot. It was corroded and floppy and missing several of the bearings. 1992 Aerostar.
Could be a balljoint as well.
1969 Cougar
357w & TKO - 475hp
Old 05-27-2005, 12:49 AM
SkylineUSA's Avatar
Re: Car is Shaking
Yep, I agree.
Jack the car up, and tug on the top of the tire, if it moves at all, then you know its something internal.
Old 05-27-2005, 09:52 AM
Re: Car is Shaking
My neighbor down the road has several mustangs, and works on all of them so he said he will look at it for me. Thanks for all the great feedback. Will let you know if I ever figure out what the problem is.
Old 05-27-2005, 12:44 PM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
Re: Car is Shaking
i bet its probably that the wheel is unbalanced and the weight fell off. i also thought about it being the wheel bearing (had some experiences with an 92 F150) since the truck had similar issues. Maybe some of the front end bushings could be worn?
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 05-27-2005, 05:31 PM
BlackGT2000's Avatar
BlackGT2000 BlackGT2000 is offline
I agree, especially that it shakes so much even when you are going slowly but more so when you are going fast.
