Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-24-2005, 01:32 PM
Rudy Abad Rudy Abad is offline
pinion seal
i've replaced the pinion seal on my 96 tahoe twice in a three month period,any idea why this goes out? i was driving driving normally both times it went out.
Old 05-31-2005, 11:11 AM
rrousou rrousou is offline
Proper fluid level should be somewhere around 1/2 inch below fill plug...any higher and it overloads the seals. If thats OK:
Check the seal surface on the yoke. If there are wear ridges, get whats called a speedy sleeve. Thats the most economical option for this, the other being to replace the yoke.
Saying that, I assume you have checked the pinions bearings and replaced the crush sleeve and set proper bearing preload and all that jazz.
Hope that helps you out
Old 06-03-2005, 12:59 PM
Re: pinion seal
..these are great tips! THANKS!
