| Off-Topic Talk about anything other than cars. |
AC removal almost done, and removing spot welds questions
1. I removed all the AC lines under the hood, the AC canister, and the radiator looking thing. Do I need to do anything to block off those old lines? Two of them run back to the firewall, two of them run to the block. Also, what can I remove from the belt system?
2. I decided to remove things on the front of the car down to the radiator support, because it was bent in a previous crash, and pressing the radiator against the turbo. The support itself is spot welded to the frame. How do I remove those welds? With a torch? I guess I'll get to learn to weld when I put the new support back on. I know these are rudimentary questions, any help would be appriciated
I used to own a DSM. Quote:
Re: AC removal almost done, and removing spot welds questions
i don't think it's a good idea to remove the radiator support, that gives you alot of your strength in the frontend.
He said he was going to put a new one in. My brother replaced a radiator support, but I didnt see the process. But they do make drill bits for removing spot welds. Never used one myself.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
none of the ac lines should go to the block. the 2 going inside just go into the evaporater. you save the most weight if you take it out but its a pain in the ass so you can just cut off the lines and leave them there.
you can just drill out the spot welds i think. just dont go too deep because you need to leave enough metal on the back surface to reweld to.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
