Old 05-24-2005, 11:11 AM
Eli Arts's Avatar
Eli Arts Eli Arts is offline
WIP: Alfa Romeo 156 by EA
my project:
What do you think about this body kit ?
PS: yaeh interior will be matt (don't worry)
Old 05-24-2005, 11:45 AM
ModifiedCars ModifiedCars is offline
Send a message via AIM to ModifiedCars Send a message via MSN to ModifiedCars Send a message via Yahoo to ModifiedCars
Re: WIP: Alfa Romeo 156 by EA
" Sand, Sand, and when you think your done sanding, Sand some more. "
Old 05-24-2005, 02:50 PM
Eli Arts's Avatar
It was sanded starting from 2500 to 3000 paper, there are some places that needs more putty becouse sanding will not help... then whole body will be sanded with sand and than polished by 3000 water paper
Old 05-25-2005, 07:51 AM
PETET's Avatar
PETET PETET is offline
Keep up the good work
[PROJEKTZ]
Old 05-25-2005, 09:55 AM
ClearHooter ClearHooter is offline
Did the screen come with it or did you add it? If so where didi you get it? I mostly do smaller scale and have been going to tobacco stores and pipe shops for my screen. They look at you funny when that's all you buy. I assume by the surroundings this is larger than 1/24? Looks good so far. Going to be Alfa Red?
Old 05-25-2005, 12:49 PM
Eli Arts's Avatar
Re: Re: WIP: Alfa Romeo 156 by EA
-I have added screen. I don't what was it for (becouse I have found it somwhere in house) but probably it was for pipes...
-No it is 1/24
-I still don't know the color, it was Alfa Red, so I want to change somethnig I was hinking about white pearlesceant but it doesn't look good...
Thanks all for comments But what do You exacly think about body kit shape is not too heavy ?
Old 05-25-2005, 01:34 PM
Hobbes's Avatar
Hobbes Hobbes is offline
The unusual suspect
Looks good, but I think the bodykit needs to be a bit shorter. And the rear needs a vent or two...
Blue or yellow are always good colors...
Old 05-30-2005, 10:49 AM
nosliw2004's Avatar
nosliw2004 nosliw2004 is offline
Send a message via AIM to nosliw2004 Send a message via Yahoo to nosliw2004
it looks nice but i think the side skirt needs something but im not quite sure wut
Old 06-02-2005, 12:49 AM
visible33's Avatar
visible33 visible33 is offline
Send a message via MSN to visible33
Like I see you had made all spoilers yourself ?
You had done very big work, I know this because country where I live there isn't shops where can you buy parts so i have to made all spoilers with car filler.
Keep up good work.
Old 06-02-2005, 09:49 AM
nosliw2004's Avatar
i see that u have filled up the rear door lines are u trying to make this a two door car?
Old 06-03-2005, 01:34 AM
visible33's Avatar
When you want to do this car two door car you must make the body little bit shorter.
Old 06-03-2005, 04:50 PM
Eli Arts's Avatar
yest it will be 2 door but it won't be shorter... There will be a 3.0 V6 central engine
Yes i have done whole bodykit by myself
And I also think that the sideskirt need something else.... but what ???
Thanks for commnets
Old 06-03-2005, 11:43 PM
visible33's Avatar
I think you should make one vent-hole in the corner of sideskirt :
But it's quite hard work and you have to demolish a lot.
