Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 05-24-2005, 09:32 AM
whatsontv whatsontv is offline
2000 Beetle Catalytic Converter
Hi All
This may have been asked before, so I apologize in advance... I bought a used 2000 Beetle last year, and this week the check engine light came on and it started to make a rattle sound under the car. My mechanic says that the Catalytic Converter needs replacing, and to do that he has to basically replace the entire exhaust system. This has been a good car, so imagine my surprise at a $1,600.00 repair cost (with labor).
Help! Does this sound correct?
Thanks!
Old 05-25-2005, 01:40 PM
boschmann boschmann is offline
Re: 2000 Beetle Catalytic Converter
The VW cat is very expensive, on the aftermarket they're less than #300. If it still had <80K miles it would have been under warranty.
Old 05-26-2005, 07:19 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I would say have the shop put the car in the air and have them actually show you the cat is rattling. You only need to replace the catalytic converter if its bad, not the whole exhaust. new vw exhaust dont go bad accept where the midpipe bracket mounts to the body right behind the catalytic converter which can also cause rattling. cats are a big purchase and they should show to you that the cat is rattling.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
