Old 05-24-2005, 09:17 AM
notsocool notsocool is offline
air conditioning
1996 LeSabre - when the car is started and the AC is turned on, the cool air blows out the defrost windshield vents and the floor vents. After about 5 minutes the air blows correctly out the dash vents. Any ideas?
Old 05-24-2005, 11:25 PM
yogi_123rd yogi_123rd is offline
Re: air conditioning
It sounds like you have a weak/leaky vacuum connection.
The AC/Heater vent system works off engine vacuum. The default (i.e. no vacuum) sends air out the defroster. In the engine compartment, a rubber hose goes to a vacuum accumulator connection (small+ boxlike located on firewall down and to the left of the master cyclinder). A second plastic hose also connects to the vac accumulator and goes thru the firewall to the AC/HEATER unit. The usual problem is that the rubber vacuum hose dryrots or falls off. Check for a good connection here as you may be getting partial vacuum.
