Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-24-2005, 09:11 AM
moemel moemel is offline
No low beams
I have a 2000 Impala. the other night I was driving and I held my flash to pass in for a little while when I let it go I had no low beam headlights still have highs. changed bulbs still no lows checked fuses still no lows any IDEAS please help
Old 05-24-2005, 02:27 PM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Re: No low beams
Sounds like you somehow managed to get the car stuck on high-beams... Not that I know how to fix it off hand. I'd keep playing with the lights, at worst, ask a shop about it.
Old 05-24-2005, 04:23 PM
ogre73 ogre73 is offline
Re: No low beams
When are you checking? I ask because if you are checking in daylight, with the headlight switch off you may be seeing the daytime running lamps. When they come on they are actually the high beams (inside set of lights; the outside are the low beams) set to a lower voltage so they aren't as bright.
IF this is the case, putting the emergency brake on before turning the car on will disable the daytime running lamps. Turn the headlight switch on and see if you get dim and high then.
If not, sorry. I've never heard of this before.
Old 05-24-2005, 09:46 PM
No it happens at night.
Old 05-28-2005, 07:20 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Re: No low beams
Did you check fuses, god knows they are all over the place in that car. Did you recently go anything to that car...i have heard of this one other time but i never did find out what was the problem....i will look into it more and let you know
mike
Old 05-28-2005, 09:26 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Re: No low beams
could be a possibale bad DRL relay, possible not likely.
Old 06-24-2005, 04:36 AM
dmorlow dmorlow is offline
Re: No low beams
It really sounds like you messed up the "flash to pass" feature. Like you said, you heald it in for a while. Maybe you were holding it in too hard and broke it in the steering wheel. No clue how you're going to fix that one. But I bet that's what's wrong. I don't dare to take apart these steering wheels with airbags anymore.
