Old 05-24-2005, 07:57 AM
alsdock alsdock is offline
'94 voyager drivers side door lock
The drivers side power door lock stopped working by both the remote and the switch on the door panel. All other doors are fine. Any thoughts?
Old 05-24-2005, 10:06 AM
sandokana sandokana is offline
Re: '94 voyager drivers side door lock
Most likely your power door lock actuator went bad. Remove your door panel and your speaker if you have one in the front door.
The out side of the door you will see three torx drive bolts- remove them, then from the inside disconnect the electric plug and links from the door lock. You can pick up a used actuator from a junk yard for a few dollars.
