Old 05-24-2005, 07:12 AM
tnelson256 tnelson256 is offline
Send a message via AIM to tnelson256 Send a message via MSN to tnelson256
Angry thump between tracks
im so mad... i cant find help anywhere. whenever i change tracks manually or switch from cdplayer to radio or the other way i get a loud thump from the subs. i havent got any ideas on what this is and its soo annoying and driving me crazy. any help?
Old 05-24-2005, 08:32 AM
MStout's Avatar
MStout MStout is offline
Re: thump between tracks
Check your ground, either its not big enough or you dont have it mounted to bare metal. That would be the first thing you should check whenever you hear anything like that.
Old 05-24-2005, 08:36 AM
thanks i will check that this afternoon
Old 05-24-2005, 12:12 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Its most likely the HU...... lemme guess old pioneer?
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 05-24-2005, 03:07 PM
Angry
well its not the ground (tried 3 different spots and made sure good contact) and its not a pioneer, i have a kenwood.
Old 05-24-2005, 03:32 PM
hmmmm i still think its the HU!!
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 05-24-2005, 03:42 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
i know a couple of HUs that do the same thing, and my stuff does it when i turn it off/on, never bothered me though.
Old 05-24-2005, 05:56 PM
yea i have heard about amps doing that when it turns on and even for me this would not be a problem but this is every time i change tracks.. maybe ill swap decks with my friend and try that
Old 05-24-2005, 06:15 PM
it might jsut be the lack/gain of signal thats causing it
Old 05-26-2005, 12:37 AM
ec437's Avatar
ec437 ec437 is offline
I also have a kenwood HU that thumps the sub between tracks and while using the radio. But I got mine for free, so I'm not complaining. I did find that hooked up a different way, (with the PCON to the power antenna lead and not the CD player circuit lead) I got no thumping when the sub was idle, but it also did not do anything when playing a CD.
I decided that techno trance parking lot dance parties are a much better use for the subs than morning radio talkshows, so I put up with the thumping while I'm listening to the radio.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 05-26-2005, 03:04 PM
no, i want my subs so i can listen to talk shows!!!!
Old 05-28-2005, 06:12 PM
3dees 3dees is offline
Send a message via AIM to 3dees Send a message via Yahoo to 3dees
thumping
are the rca's going down the same side as the power wire? if it is your getting feed back. you get engine noise and all sorts of sounds from that. if they are separated. change the rca's. if thats not it. process of elimination. its the power supply in the amp. try rca's first. its most likly them.
Old 05-28-2005, 06:16 PM
thumping amp
you get that noise typically when the rca and the power line are run side by side down the same side of the car. it creates feedback. if the rca's are separated from the power line. its still the rca. change that. if it aint that. then i got bad news. its the amp. the power supply has craped out.
Old 05-28-2005, 09:50 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
some myths just never die ...........
Old 05-29-2005, 06:37 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
One idea to try is to insulate the RCA connectors with electrical tape or something. I found that my Knu Konceptz twisted pair RCAs found places to touch the chassis behind the deck, and it made the nastiest noise I've ever heard in my car. A little split loom wire wrap fixed it right up. If switching the deck and/or the amp doesn't fix the problem it may indeed be your RCA wires or their placement. If you have a few hours some weekend or afternoon, you can completely rewire your car.
Just so you know, it doesn't take much skill. I pulled my passenger seat, rear seat, and most of the rugs up, ran 3 twisted pair RCAs, main power and ground, speaker wires, hooked up crossovers, and mounted and adjusted the amp in just an afternoon. It looks awesome too. Check it out!
