Old 05-23-2005, 11:34 PM
punkytoole punkytoole is offline
Send a message via AIM to punkytoole
lumina gague cluster
i have an opportunity to buy a gague cluster from a 92 z-34 (the one with 5 gagues, speed, tach, fuel, temp, and voltage + trip odometer) and i was wondering if i could replace my gauge cluster from my 91 lumina (2 gagues, speed and fuel) with that one.
Old 05-25-2005, 09:44 AM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Re: lumina gague cluster
You can use the Euro UB3 cluster, but it won't be plug and play for you. You will have to run a wire from your ignition module tach wire (white) for your tach to work. Because you only have a temp light, and not a gauge, you have to change your temperature switch to a temperature sender unit so that the gauge will read correctly. Not sure about the volt meter.
Old 05-25-2005, 11:24 PM
Re: Re: lumina gague cluster
thanks, thats what i was wondering. so now i just have to consider how much work all those gagues are worth to me
Old 05-26-2005, 01:24 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Not that much work for the benefit of a full cluster.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
