Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 05-23-2005, 11:28 PM
brap316 brap316 is offline
96 dode avenger es question??
I have 96 dodge avenger es (DUUHH) and just recenltly i notice when i am in idle it slowly moves toward over heating Maybe about a inch or two past the middle but when im driving it stays at the middle. I have had the radiator flushed and checked all my fluids . Could this be the begining of something worse?? ....or something simply like a dirty hose or something. I had the themostat replace about 4 yrs ago would it be time for another??? any advice would be grealty appreciated
Old 05-24-2005, 02:11 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: 96 dode avenger es question??
well this probably isnt it... but on my old escort the exhaust pipe fell off and when i was sitting still at idle the exhaust gas would rise up and actually hit the thermometer causing it to rise way up
Old 05-24-2005, 09:23 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Have you ever owned an Avenger? You sure spend a lot of time in here for a guy who owns a Mustang. Just curious.
My Mopars
Old 05-26-2005, 08:52 PM
TheStang00's Avatar
Re: Re: 96 dode avenger es question??
well no one else spends any time in here... lol and my brother currently owns one and ive helped him do a bunch of work on it. soon we're gonna put a turbo on it, we already have the turbo but we just need to stick it on.
Old 05-26-2005, 11:23 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Check and make sure that your fan is comming on. Just remember that when the car is moving it doesn't need the fan to move cool air over the radiator but it does at when your sitting still.
Old 06-08-2005, 11:40 PM
JackDaniels386 JackDaniels386 is offline
yea, like polygon said, make sure the fan is coming on. if its not, change ur coolant temp switch.
Old 06-28-2005, 07:09 PM
d-money d-money is offline
I would also suggest checking your water pump and hopefully it's not the head gasket about to go south on you. Mine gave me the same problems and then the head gasket went out. While I was doing the gasket I replaced the head on my 95 with one off a 99 Eclipes with 20000 miles on it and have not had any problems since.
