Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-23-2005, 07:45 PM
robeson114 robeson114 is offline
Talking NUDE supermodel on hood of JGC
That would be nice... But since I've got your attention, I do have a quick question. Does anyone know what the correct idle speed for a JGC 95 automatic is suppossed to be? I replaced IAC and TPS and it seems to be idling lower, around 550 - 600rpm , than usual. ANy help would be greatly appreciated...
Old 05-24-2005, 12:02 AM
bgmoss28 bgmoss28 is offline
Re: NUDE supermodel on hood of JGC
Interesting way to get our attention...
I have a '96 JGC that idles right around 700 or so. I wouldn't think there would be much difference between yours and mine.
Old 05-24-2005, 12:22 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
robeson114, your idle speed seems to be right, anywhere around 600 is good.
Old 05-24-2005, 09:57 AM
Caribbean ZJ Caribbean ZJ is offline
Bout 700 at cold startup then 500 at op temp. U owe us girl pics.
Old 05-24-2005, 12:15 PM
clr114 clr114 is offline
Talking
Sorry about the deception... I fell for it a few times, just thought it would create a few smiles...
Maybe my idle seems lower than usual because its a little rougher. I probly just need to properly gap my plugs. I put some bosch plugs in it recently and didn't gap them, just put them in stock. would that cause much problem? The jeep drives down the road smooth as butter. Its when I stop and idle that causes problems. Well, thanks everyone for your input.
Old 05-24-2005, 03:34 PM
try cleaning the Throttle body or replace the IAC unit. Nothing beats champion plugs on Jeeps
Old 06-01-2005, 12:13 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I would think it would idle MUCH faster if you actually had a naked model on it.
As far as not gapping your plugs, you've probably already done it and found that things improved greatly.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-05-2005, 01:46 AM
jeep mechanic jeep mechanic is offline
check map sensor!!!and pcm!!!
check map sensor values, ive had the same problems, i also replaced my tps, iac, then come to find out the pcm and the map sensor was bad. im am now awaiting parts. it seems chrysler has a bad batch of map sensors mines on back order.. try to avoid buying these parts from places like autozone,advance auto,and stores like that. they are generic and yours may be vehicle specific. ive been thru 2 already and one pcm. pcm is pricey $490.00 i found a used one.
THE EARLY BIRD MAY GET THE WORM...BUT THE 2ND MOUSE ALWAYS GETS THE CHEESE!
Old 06-05-2005, 03:38 AM
ramairgto72
Guest
Posts: n/a
You don't gap bosch plugs!!!!! You will mess up the plug if you try, they come pre gaped.
