Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-23-2005, 05:51 PM
Schrade Schrade is offline
Forget The O2 Sensor!!!!!!!!!
WAY BAD CALL 94JIMMY!!!
A finely tuned motor does NOT even use the O2 sensor. A finely tuned motor uses all of the O2 which gets burned in the combustion process, and the O2 sensor does no work. A poorly tuned motor lets O2 get through the combustion process (by not burning it all), and into the exhaust, and the O2 sensor tells the ECM that compensation is necessary to fix another problem. If you'd like to see that in print, I'll be happy to get it to you. A bad O2 sensor is an extremely common myth!!!
Old 05-25-2005, 10:00 AM
Fireplug Fireplug is offline
Re: Forget The O2 Sensor!!!!!!!!!
Thats a load of crap. In the Auto 4 stroke engine you will never get 100% fuel and air burn. If you did there would be 0 emissions and only water vapor out of the exhaust. Also there would no need for a cooling system because with 100% use of fuel and air there would be NO heat left to cool down.
Old 05-26-2005, 01:34 PM
wafrederick wafrederick is offline
Banned
You are full of B.S.The Electronic Fuel Injection will not work right without the O2 sensor.The O2 sensor work with the fuel injection to read the fuel/air mixture.A bad O2 sensor is NOT a myth,you liar.Antifreeze can do damage to an O2 sensor after a blown headgasket.If a check engine light is on and it is an O2 sensor code,the O2 sensor is bad.
Old 05-26-2005, 06:17 PM
Wafrederick
To whom are you speaking to?
You statement
Well with 15 years as a GM Master Tech And A.S.E Master Tech you last statement is so WRONG.
Most O-2 codes are caused my a fuel or spark problem not by a bad o-2 only. Sure we get a few truely bad o-2 sensors but not like what you think.
Old 05-26-2005, 06:38 PM
Dirtsled Dirtsled is offline
I ran out of gas once and the puter threw a O2 sensor code , O2 sensor replacement tends to happen a lot more than needed.
(Not a pro but well informed)
Old 05-26-2005, 08:30 PM
And why did it put the cel on because the fuel system went very lean, o2 code set but not a o2 problem
Old 05-26-2005, 10:14 PM
Banned
Sorry,I was speaking to cbec1999.I still think cbec1999 is full of B.S.I do remember what will throw an O2 sensor code,a topped off gas tank.It happened to my grandma's 2001 Saturn,replaced the O2 sensor three times until my father found out.My grandma topped off the gas tank and it did set that O2 sensor code off.Found this out from a Vetronix rep my father knows that helps out my father on computer headaches
Old 05-27-2005, 09:25 AM
You sure it was the o2 code and not the evap fuel tank code?? because that is a very common problem if the gas cap is not turned on tight with the min of 3 to 5 clicks on the cap
Old 05-27-2005, 05:11 PM
Banned
It was an O2 code those three times.After the third time,my father called that Vetronix rep and asked him that.That Vetronix rep is a friend of my father, like I mentioned help my father out on the computer headaches and is "right on the stick" most of the time.Anyway,GM's factory scan tool is made by Vetronix
Old 07-06-2007, 12:05 PM
Like I said before...
Forget the O2 sensor.
I got the article right here in my hot little hands. Took two years to find it too. Corvette Fever, Nov. 2000 'How to tune a TPI'.
How can I upload the pic there, mods?
Old 07-06-2007, 12:36 PM
abaird abaird is offline
Sounds like a comic book to me.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 07-06-2007, 02:13 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Same thread as in the C/K forum,and an old resurrected thread at that.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
