Forget The O2 Sensor!!!!!!!!!!
WAY BAD CALL 94JIMMY!!!
A finely tuned motor does NOT even use the O2 sensor. A finely tuned motor uses all of the O2 which gets burned in the combustion process, and the O2 sensor does no work. A poorly tuned motor lets O2 get through the combustion process (by not burning it all), and into the exhaust, and the O2 sensor tells the ECM that compensation is necessary to fix another problem. If you'd like to see that in print, I'll be happy to get it to you. A bad O2 sensor is an extremely common myth!!! |
Re: Forget The O2 Sensor!!!!!!!!!!
Uhhhhhhh????????
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
Just because a "finely tuned" motor uses all of the O2 that comes into the chamber does not mean that the sensor is not working. It is absolutely working. A sensor is just that, it does nothing but sense. It recives a signal and sends a signal. I'm sure you realize that a motor does not stay in tune by itself. It needs constant attention whether you know it or not. Those sensors help keep the motor running efficently until scheduled maintence time. Sensors can and do go bad including the O2 sensor.....If the engine didn't need it, they wouldn't use it. Jake
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not."" -George Bernard Shaw "Mind over matter: If she doesn't mind, It doesn't matter" -Nineball
Unplug a few of your injectors, and remove a couple of your plug wires while you're doing away with your o2 sensor. Those plug wires are just extra weight.
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
This is hillarious. Remove them and see if the 'check engine' light doesn't come on....it will.
*Under Construction - New sig to debut* |
Yes, the ECM uses data received from the 02 sensor(s) to correctly adjust the air fuel mixture for the ever changing conditions. This is a constant process when the system is in closed loop. Without the sensor operating all of the time, the engine performance would certainly suffer with a moder fuel injection system.
And yes, the sensors can and do go bad. Either electronically, or other means like fouling that puts them out of specs. And where did this thread come from? |
Probably an online "troll"
The only way to get rid of the o2 sensors is to fool the system by putting in o2 sims. And all they do is simulate the actual sensors as if they were working properly. Kinda stupid if you want to make sure your motor is still running correctly though!
come on guys, havent we beaten this guy up enuf already? no. ahahaha. please dont listent to this person if ur lookin for "tuning" advice. maybe u could get rid of the sensors on the very first cars ever equipped with them, but not new ones. im curious tho, because i like to give people the benefit of the doubt: cbec1999, do u have them on ur truck? if not, and it still runs properly, let alone at 100% percent efficiency which is all but impossible, then we all owe u an appology.but i doubt it. ok now i think hes been properly abused emotionally. and the simulators arent all bad if u have an engine tuned to a point where u need them.which i dont, so i can only offer a partial opinion.in fact, scratch that. i cant offer one at all lol. i just got a big mouth. id leave the sensors on unless i had no alternative. its just not worth the headaches. thats an opinion that comes from experience.i have an old truck thats not at all legal and never will be, but as far as the new one goes, its gonna stay on the up and up untill it costs me a race with somethin from Jay-pan.(no rice here baby!)
I'm telling you, the weight loss from yanking a few of those plug wires is hard to beat.
heck yes cuz! im from jersey where races involve not just the top speed, but how quick u get to it.every hundred pounds is a 10th in the quarter mile they say...
sorry i almost forgot lol. look on here for Slowprocess, hes runnin a not-so-stock 6.0 in his 1500 and went 12.5 at 105.ask him if hes got sensors on his exhaust.i couldnt tell u if he does or not, but whichever the case is he appears to have made the right move to me.
I'm pretty sure he doesn't..seein as he has long tube headers and cutouts..
1998 ECSB Z71
