Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-23-2005, 05:48 PM
redjeep89 redjeep89 is offline
Jeep Performance parts
So I'm probably stupid to even want to spend extra dough on performance parts for a 4 cyl 2.5, but my 95 wrangler is like my hot rod, so why not treat it right.
I want to set up a performance ignition for a hopefully better idle, and I need some ideas. Nobody makes real good aftermarket stuff for the wimpy (yet bulletproof when need-be) 4 cylinder.
MSD and Accel make universal wire kits that I can cut to size, though I'd like to go with an ignition coil and distributor cap/rotor too. I can find all kinds of universal coils to choose from, but I wouldn't mind suggestions.. and I'm having the toughest time finding an aftermarket cap and rotor for it. Apparently nobody wants to supe up a 4 cylinder unless it's fast and furious. On that note, anybody know if the Neon has the same distributor by any chance? I may be able to find a performance one marketed for that.
Thanks-
Old 05-24-2005, 04:08 PM
btjeep20 btjeep20 is offline
Re: Jeep Performance parts
performance distributors makes an ignition kit for the 2.5L for about $190. It comes with plug wires, coil, cap and rotor
Old 05-25-2005, 03:23 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Talking
on www.4wd.com there is a set of Jacobs Ultra wires pt# 4007497 which lists for $39.95
There is a spit fire wire set for $52.95 pt# 4707
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 06-02-2005, 03:05 AM
CanaMark CanaMark is offline
what will a performance cap and rotor do for you? will it gain HP? Can you get one the you can program stuff into, like where it idles at?
Old 06-02-2005, 09:07 AM
Well, I personally don't expect to gain any HP out of a performance cap and rotor. Not to say it can't be done, anything really can be done with the right parts and enough money. For my application, (the 4-cyl), I'm hoping for a cleaner idle at most. A hotter spark (with a better coil), less resistance in the wires, etc, can hopefully achieve that.
Cap and rotor, there really isn't any idle "programming" or adjusting, it's just a matter of it running more solid. Now some distributors (like the performance distributors link someone added to this thread), I don't believe they're programmable, but I though I remembered seeing some form of adjustment built in to them.
Old 06-02-2005, 10:31 AM
o|||||||o o|||||||o is offline
Send a message via AIM to o|||||||o
www.4wd.com
www.quadratec.com
www.4x4groupbuy.com
and that is 3 just off the top of my head.
That is the nice thing about Jeeps. There are more aftermarket parts out there than you would ever need.
2004 Jeep Wrangler Rubicon (Modified a lil' bit)
2003 Honda VFR 800 (All stock w/ABS, just like Honda built it)
2001 Ford Crown Victoria Police Interceptor (It looks like a cop car because it is one)
