Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-23-2005, 06:14 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Injectors...
Hey everyone. I recently bought a 1995 GSX, after buying it the previous owner handed me a zip-lock bag of fuel injectors that he had bought for the car but not installed. I believe the 4 injectors are 650cc. I'm not sure if it is a good idea to install them or just overkill on my car. My 95 GSX setup is an RNR 3" turboback with o2 eliminator, extreme motorsports fuel pump and manual boost controller, SAFC, and an hks turbo timer. Please let me know what you think.
Old 05-23-2005, 08:05 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Injectors...
errr, yes, and no. you can install them, and use safc to dial them in, but you have no reasion to do so yet. did he have a larger turbo on the car at some point? you dont even need the safc with your current mods.
DSM geek
Old 05-23-2005, 10:48 PM
NateS's Avatar
I'm not sure. The stock turbo on it now was just put on when the engine/trany was rebuilt. So I'm not sure if the previous turbo was stock or not.
Old 05-24-2005, 02:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Injectors...
The AFC is still usefull, even on a stock car. Dont forget that stock target AFR is 9.5:1.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-24-2005, 08:45 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Injectors...
I don't think you should install. You should sell them to me for dirt cheap. Sorry, I had to try. If you do decide to install them, you will need a logger. Check out:
www.pocketlogger.com
Look under the OBD-II section.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-24-2005, 04:50 PM
NateS's Avatar
logger
Ha yeah...fourtunatly a logger came with the car too.
