Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 05-23-2005, 04:54 PM
stopufool's Avatar
stopufool stopufool is offline
Clean B16 head
Hey i recieved my b16 head, that i will replace my old one with. Just wondering if it is ok to hose it down, in delivery it somehow got lint on it in some parts, the guy packed the box with massive amounts of t-shirts. Also to get rid of old sut that has been built up over the years
anything you guys would recommend to clean the outside as well??
Can't wait to get this on the road, the head has a .10 port and polish, skunk2 dual valve springs, crower titanium retainers, CTR cams, and skunk2 adjustable racing gears. sweet huh
Old 05-23-2005, 04:59 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Clean B16 head
very sweet, id just wipe down the internals first, then after the install, steam clean the engine, itll look new
Old 05-24-2005, 04:54 PM
stopufool's Avatar
would it hurt if i took a hose to it? like nothing would get damaged right?
Old 05-24-2005, 05:05 PM
Kind of a Big Deal
Re: Clean B16 head
as long as you cover up the electronics
Old 05-24-2005, 05:33 PM
stopufool's Avatar
Re: Clean B16 head
yeah no electronics are hooked up, so i will just take a hose to it on the weekend and let it dry out
Old 05-24-2005, 09:52 PM
Kind of a Big Deal
Re: Clean B16 head
make sure the internals dont sevelope surface rust....istill think you should mount it, then clean it..
Old 05-24-2005, 11:51 PM
97integrals's Avatar
97integrals 97integrals is offline
Re: Re: Clean B16 head
Yes if you rinse it with water and let it dry it will rust, I would suggest getting it hot tanked.
Old 05-25-2005, 01:54 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: Clean B16 head
rust!!! that's exactely what came to mind when he said leave it sitting with water on it.
Old 05-25-2005, 03:04 AM
bill-the-ba$tard bill-the-ba$tard is offline
Send a message via AIM to bill-the-ba$tard
Re: Clean B16 head
Hot tank it?? Not unless you are replacing all the rubber components. Water won't get that buildup of soot and whatnot off, but you can use water, as long as you dry it out with compressed air or a blow dryer afterwards, then immediatly coat everything with motor oil.
Just wipe it down. Any lint you don't get will come out in the next oil change.
Old 05-26-2005, 03:19 PM
I was simply telling him what I would do. I like to do things right and not cut corners. He already has the head off and with a little disassembly time and a minimal amount of money he can be sure that there is nothing in side that will ruin his motor. He also bought this head from a third party so who knows if any of the parts were installed correctly, by disassembling the head and getting it tanked he can make sure all the clearances are dead on and everything is in good order. I never recommend put water on any internal engine part!! And telling someone to install the head and hope everything comes out in the first oil change is moronic.
Old 05-26-2005, 07:11 PM
Re: Clean B16 head
You never said anything about taking it all apart. From what you said, it sounded as though you wanted him to just drop it in the tank as is. I do definately agree with you though that to do it right, you should get a whole head set and replace all the valve stem seals anyway and other rubber components.
However, to do it cheaply, washing it with water would be worse for it than simply wiping out all the lint possible. A little lint won't hurt anything if it is soaked in oil. If it has any sort of grit at all though, a rebuild (including, of course, the hot tank) would be highly recommended.
Old 05-27-2005, 04:10 PM
stopufool's Avatar
Re: Clean B16 head
Ok well i am not gonna hot tank it, i want to do this fast and cheap, so if i hose it down, then hand dry it real quick in the sun, then put some oil on the surface all around i should be fine then?
Also how do i clean out the ports while i am at it, get a pipe brush or something?
Old 05-27-2005, 04:15 PM
stopufool's Avatar
Re: Clean B16 head
Also how much horsepower do you think this setup would give, the specs are below
Cold air intake - AEM bypass
Skunk2 Intake Manifold
CTR cams
Skunk2 cam gears
Crower TI retainers
Skunk2 Dual valve springs
.10 port and polish B16 head
DC sport headers
Aem Underdrive pulley
