Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-23-2005, 03:34 PM
rshah188 rshah188 is offline
interior neons
i am trying to hook up interior neons to my 1998 Mustang. Someone told me a quick way of installing them was to wrap the positive wire from the neon to a fuse is the fuse box, and the negitive wire around somethin metal that touches nothing else. Is this a good way of doing it? or is there a better way to go about it?
Old 05-24-2005, 03:50 AM
KimMG KimMG is offline
AF - Advisor
Re: interior neons
I would look at a wiring diagram and pick a circuit, then use wire connectors (or solder) to splice into the positive circuit. For the ground, I would crimp a connector on the wire that could be screwed to the body.
Old 05-31-2005, 01:54 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: interior neons
if you hook it to a fuse or circuit you run the risk of overloading and causing blown fuses, or worse, a fire in your dash, you'd be safer to run aftermarket electrical stuff off the battery, for the ground KimMG has the right idea, find a screw or bolt and attach it there
Old 06-01-2005, 12:21 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Re: interior neons
. Well, whatever, its your car. But if you do it, do it right. Run a fuse on the 12v side, and put a switch on the ground side to do it right.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
