Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-23-2005, 01:04 PM
civicfreak1 civicfreak1 is offline
Quiefe vs Honda LSD
ppl which one is better ?>???
queife or type r lsd....
i have got both ...
but if they r exactly the same then i shouldn't take my gear box apart..
Old 05-23-2005, 03:56 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Quiefe vs Honda LSD
this is one of those questions where some will say Type R and others will say queife... if you have LSD already, i would bother pulling it apart only to put another LSD in (unless your current one is giving you problems.
Old 05-27-2005, 07:13 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
come on green, everyone knows nothing beats qauife
Team Lonely Drivers
Old 05-27-2005, 07:21 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Quiefe vs Honda LSD
I don't know anyone that would say the ITRs is better than the Quaife.
Old 05-27-2005, 07:33 PM
Kind of a Big Deal
not exactly "better" but some would say whats the point if you already have a LSD in your tranny.
Old 05-28-2005, 12:23 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
CUSCO!
Old 05-28-2005, 01:03 AM
Kven's Avatar
Kven Kven is offline
Cusco is a different style than Quaife and Honda. Cusco uses clutch plates while Quiafe and Honda(?) use a torsen style diff. IMO, the Quiafe and Honda units are better for Road Course, while the clutch type works good on drag cars and RWD cars.
I would vote Quiafe but that's only if you need it(like big increase in power), otherwise stick with the OEM one. Mechanically they are the same(that is if the Honda one is a torsen style) but the Quiafe should be stronger since its designed for the aftermarket.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 05-31-2005, 08:20 PM
clutch type lsds are better for road races. the problem with quaife is that if your road racing and one of your tires goes into the air, you lose the lsd ability. but if you have a clutch style lsd, it will work.
just like if you break an axle with a quaife you still cant drive it because it needs some resistance on the other side, only a clutch style lsd will grab with a broken axle
Team Lonely Drivers
Old 05-31-2005, 09:34 PM
Kven's Avatar
the only thing that sucks about the clutch is when it is engaged, it forces the two sides to move at the same speed. as we all know, in a turn, the inside wheel is suppose to turn slower; a torsen LSD works best for this. but yea if you encounter bumps and have a high-output(torque-wise) motor, a clutch lsd would be good.
1988 Honda CRX DX
