Old 05-23-2005, 11:52 AM
djnagle djnagle is offline
Is my Fuel Pump bad?
Ever since I've had this 93 Voyager, I could hear the fuel pump buzzing away in the back of the car. I tried to start it the other day and it would not start and there was no buzzing in back. I pulled the air filter and sprayed some starter fluid in and it tried to start. I have looked for a fuse or breaker for the Fuel Pump but can not find one. So, do you think the pump just gave up the ghost or is there some little trick I am not aware of?. Thanks in advance.
Old 05-23-2005, 07:38 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Is my Fuel Pump bad?
If you don't hear the pump charging the system then it has probably gone bad and will need to be replaced. Make sure you check the fuse and the fuel pump relay first as this can cause the same problem. If both check out then the old fuel pump has to go.
Old 05-23-2005, 10:33 PM
Re: Re: Is my Fuel Pump bad?
Hi GTP Dad, I looked throughout the Owners Manual and it did not list a fuse or breaker or relay for the fuel pump. Is it listed as something else? Thanks.
Old 05-24-2005, 05:40 AM
Pontiac Guy
The fuel pump fuse and relay should be in the power control center under the hood. If you look on the inside of the top is should show which fuse powers the fuel pump and which relay is the fuel pump relay. Most owners manuals don't show these to you as the manufacturers don't want you working on them. Once you know where to look though they are not hard to find.
Old 05-24-2005, 08:19 AM
Thanks so much GTP Dad. As soon as I read your post I ran out and checked it.........looks like I will be replacing a fuel pump. Cheers.
Old 06-10-2005, 01:10 PM
Windywoes Windywoes is offline
Send a message via AIM to Windywoes Send a message via Yahoo to Windywoes
Re: Re: Re: Is my Fuel Pump bad?
I went through this on my 1990 GC. $600 later it worked fine. Most of my fuel lines were badly rotted so they needed replacing. If yours are in good shape the cost should be lower. The tank has to come out to access the fuel pump.
