Hey Guys
I have a 99 Burb 4X4, 56000 miles and what seems to me as a rough idle or a miss. No SES light and I have changed: Cap & Rotor Plugs Fuel Filter Air Filter and ran some injector cleaner through it. It seems to only happen at stop lights or when parked at idle. Doesn't hessitate or stall when you step on it. Also when comming off the interstate or from driving for a while without stopping it will not do it for 30 - 35 seconds after stopping. Another concern is at speed when going down the interstate. First noticed it last month, when I hit about 75 it seems to have a viberation or a slight rumble. Once I get to about 78 it goes away and everything is fine. Any Ideas? Thanks
2011 Chevy Malibu 2012 Dodge Ram Crew Cab (Camper Puller) 2003 Trailblazer LS 4X4 1990 GMC Full Size Jimmy 4X4 RIP
Re: 99 Burb
Bump - I'm all ears on the vibration between 65-75. Mine is fairly in consistent but definately annoying. 51000 miles and everything is good as far as u-joints etc.
Anyone? |
Re: 99 Burb
try having tires ballanced runble my be tires if you feel it in the wheel and only at certain speeds, could also be a cv joint but i'ld try tires first.
technology is great when it works but one big pain in the ass when it doesn't Detroit Iron Rules, all the rest are just toys!
Re: 99 Burb
Tires good, did that.
Running Michelins with the normal dealer aftermarket wheels. CV's? I'll look into it... Thanks! |
Re: 99 Burb
when was the last time they were ballanced? you can throw a weight just hitting a pot hole and it will act like your taking about. michelins are good but they still need to be ballanced i threw a weight on a set of dunlops the day after they got put on, on my fiero and it did the same thing your talking about.
Re: 99 Burb
I am not sure this will help, but I have a 1996 2 door Tahoe with 175,000 miles. Mine has a vibration in it that starts at 65 MPH and will stop when going above 73 MPH. After lots of checking it seams to be torque converter shutter. If you fix it please leave a post as to what it was. Thanks Dave
Re: 99 Burb
Re: 99 Burb
Thanks for the info Scott. It is really annoying but I agree not worth the money. Just makes me nervous, i had a 99 Silverado that had clogged injectors 3 time within a 3 month period. Once 3 days after the dealer cleaned them. As long as a few of you also have this rough idle on the burbs then that helps quiet the voice in my head.
Thanks for the reply Taxman |
Re: 99 Burb
I had a 96 tahoe with the same issue, the plug wires were shorting out on the header on the passenger side.
