Old 05-23-2005, 10:20 AM
Civic DOHC Civic DOHC is offline
Oil light
I have got a new engine in my civic. The oil pump was replaced with one of my old engine. There was no problem but the dealer replaced my oil and there is a problem oil pressure now. The oil light comes on when the engine is real hot and the rpm is at 700 rpm the oil ligt is blinking but not real bright. Is my oil pump bad or what?
Old 05-23-2005, 10:40 AM
2CrX's Avatar
2CrX 2CrX is offline
If its not real bright it could be a short, but I wouldnt drive it until you find out. If I rember correctly the oil light dosent come on untill a very low psi, dont want to fuk up your motor.
Old 05-23-2005, 07:18 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Oil light
sounds like they might have hit the oil pressure sensor when changing the filter. its right above the filter. if they snagged it, it may be sending a weak signal, causing it to light slightly. id check that
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
