Old 05-23-2005, 08:33 AM
PARoadRunner PARoadRunner is offline
'96 Caravan Cold startup issue
I'm kind of a car newb so this might be an obvious problem to some of you, but here goes. Just last week my caravan began having starting problems after not being used for a few days. The first time, I turned the key, the car started and ran on idle for about a minute before turning off. I tried and tried to turn it on, but there were no clicks, no sounds, just the LED panel turned on when i turned the key, no engine activity at all.
About an hour after this happened I tried again and the car started right up, no problems.
Just yesterday I tried turning the car on after it had been unused for 2 days. The car again would not start, no noises at all. After a little while, I tried again and the engine started.
I think it is an electrical problem but being a novice I dont know what might cause something like this. THe battery connection to the engine? Thanks to anyone who replies
Old 05-23-2005, 01:11 PM
yogi_123rd yogi_123rd is offline
Re: '96 Caravan Cold startup issue
If it's electrical, it could be the neutral safety switch. That's the switch attached to the transmission's gear selection arm/cable and enforces that the car can only start in Park or Neutral. When it don't start, you can try wiggling the shifter arm a bit and try restarting the car.
Old 05-23-2005, 06:38 PM
vipergg vipergg is offline
I would have the battery tested , sounds weak to me . Weak batteries can cause all sorts of weird problems in these vans . Pull it and have it load tested at your local parts store .
Old 05-24-2005, 03:40 PM
leaving it outside
One more thing I notice, aside from a ton of rust on the connection clamp (horizontal clamps on baterry), is that the only times Ive had this problem was when I left the car outside overnight. Could temperature changes be a factor? (its not especially cold or hot where I am)
Old 05-24-2005, 04:33 PM
Re: leaving it outside
It certainly can be a factor on a weak battery . I would try that first as it doesn't cost anything to have it load tested .
