Old 05-22-2005, 11:07 PM
Dober89 Dober89 is offline
Any ways to fix a sticky caliper??
My front right caliper decided to stick on my way home tonight. It was pulling really hard to the right and I got out to check it and I could feel the heat from the brakes and also a burning smell.
Is there anyway I can loosen it up a bit without replacing it or rebuilding it??
I just brought it out of storage yesterday after almost 8 months and it was fine all yesterday and today, but tonight it was raining.
Old 05-23-2005, 09:29 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Any ways to fix a sticky caliper??
Lubing the guide pins should do the trick.
Old 05-23-2005, 12:43 PM
Morley Morley is offline
Probably not the caliper, the brake hoses break down inside and get blocked. The high pressure fluid from hitting the brakes will get past but when you release the pressure isn't enough to let the caliper open up.
Old 05-31-2005, 02:38 PM
Arocars Arocars is offline
I'd use a fat drill bit to clean out the holes where the guide pins go (remember you're just cleaning the holes not drilling new ones) and then lube the guide pins and re-assemble.
Old 05-31-2005, 10:33 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
My general rule of thumb is to not try to repair brake componets on a performance vheicle. Too much it as risk vs. the cost
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
