Old 05-22-2005, 09:51 PM
96dxsir 96dxsir is offline
b16a timing belt?
For a b16a 1st gen when changing timing belt which yr and should i change the water pump too also what yr?
Old 05-22-2005, 09:55 PM
2turboimports's Avatar
2turboimports 2turboimports is offline
Re: b16a timing belt?
I would assume whatever year, or generation the engine is....?
The water pump is usually replaced with the timing belt, since it's right there...
Old 05-22-2005, 10:27 PM
well i heard they would use it from a b16a3 95 del sol vtec timing and pump true?
Old 05-22-2005, 10:32 PM
It would depend....is your engine DOHC or SOHC? I would imagine that if yours was DOHC, and the b16a3 from a del sol si is DOHC they would be the same.
