Old 05-22-2005, 08:48 PM
rmunk rmunk is offline
Interior lights won't go out!
Have a 97' GL and recently the interior lights, dome and floor, will not go out, plus the door lock will not lock when starting to drive. If I push the lock switch it pops back up again. When I remove the dome bulb the door lock problem continues.
Have checked the fuses, ok and replaced one relay, interior lamp, but same problem.
Any ideas?
Thanks, Bob
Old 05-23-2005, 05:07 AM
KimMG KimMG is offline
AF - Advisor
Re: Interior lights won't go out!
Spraying the door latching mechanisms with WD-40 may clean and lubricate the door switches controlling the interior lights and fix the problem.
Old 05-23-2005, 11:35 AM
Re: Re: Interior lights won't go out!
That did the trick!! Thanks for the information and now I have a bit more knowledge.
Thanks again, Bob
Old 05-23-2005, 05:14 PM
GPFred GPFred is offline
And it works too. I had the problem show up recently and I took a shot at it with WD-40, solved the problem. Wish I had known about 3 years ago, as I spent about $60 in parts to replace the door ajar switches.
Old 06-22-2005, 05:21 AM
happyharriston happyharriston is offline
I have a 1997 Taurus GL Wagon. The WD-40 worked for me too except for in one place: the wagon door latch. I've saturated the wagon door latch several times but still the dome light won't switch "on" when the wagon door opens, and the power lock in the cargo area won't work when the wagon door is open.
Any suggestions? It's just a minor inconvenience, so I won't be replacing the latch.
Old 06-23-2005, 09:04 PM
vampiro03 vampiro03 is offline
mine does the EXACT same thing, its in the ignition. trust me, take a small peice of paper, stick it under the ignition. it will stop as long as the ignition stays "up".lol play around with the ignition when you stop and open the door, see if the beeping stops or if the lights go out.
