Old 05-22-2005, 07:48 PM
bourneville5304 bourneville5304 is offline
Send a message via ICQ to bourneville5304 Send a message via AIM to bourneville5304 Send a message via Yahoo to bourneville5304
Unhappy 97 talon does dies at random
I have a 97 talon base model, the problem i'm having is it dies completely at random. When this happens there is no fire from the coil at all. it may start in 2 tries or it may start in a week. there is no rhime nor reason, not when it's hot or cold,.. nothing. the code on the check engine light says the coil is bad. I changed it twice, I also changed the ecu. it made absolutely no difference. the ecu was from a junk yard but the odds of getting another 1 with the exact same problem are pretty slim, can anybody help me?
Old 05-22-2005, 09:03 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 97 talon does dies at random
how are the connectors for the coil. power, ground, signal, etc... you might have a loose connector or a bad ground or wire
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-22-2005, 09:10 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Re: 97 talon does dies at random
that or corroded ground/cables
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-23-2005, 09:39 AM
ok thanks for the help, i'll check those things out later,.i know the battery cables are lose do you think that could have anything to do with it? maybe just power surges or something?
Old 05-23-2005, 10:05 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
When I first got my gs it would die at random and it turned out to be a bad termanl.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
