Old 05-22-2005, 06:45 PM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
very bad....over heated, how screwed am i?
murphys law took place this weekend. One hr before i leave to go to a wedding im at a stop light and notice my check gauges light comes on. I look at the temp and its totally redlined! So im like FUCK! light finally turns green so i pull right into wallmart(where i was going just before the wedding). I cut the engine and coast into a parking space. Just before i cut the engin i heard a whining noise come from the engine. I pop the hood and there is antifreeze everywhere and i see that the lead wire for my electric water pump is ripped out. So i get the pump working quickly, run into walmart and grab some premix antifreeze. Im doing all this in a suit and tie mind you. I loosen the over fill cap and see the coolent level is near the top. So, it won't take anymore coolent. I open the bleed valves and turn on the engine to try to get the coolent movin again, cuz i know i have an air block somewhere--i just lost way too much liquid. The engine temp goes right back to redline. The pump is turned on with the first click of the ignition, so i turn on just the pump with the engine off. The air bleed nuts won't stop pissing air out of the system. So, i have a shit load of air getting into the coolent system, and no coolent moving thru the engine at all. So, before i ripp the engine bay apart looking for the source...how fucked am i? Did i possibly crack a head or could it just be a hose?
That egine squeal made me really scared that something is really fucked.
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 05-23-2005, 05:48 PM
volkerc's Avatar
volkerc volkerc is offline
Re: very bad....over heated, how screwed am i?
sorry to hear that. but you are not alone, happened to me twice, with no damage. I'd say you might have been lucky if it only occured once and you stopped immediately as it sounds. I would check the coolant for signs of bubbles or oil after a while. No sign of any and you should be good. ...
