Old 05-22-2005, 04:46 PM
dwestcorp dwestcorp is offline
92 Cavalier 2.2
92 Cavalier 2.2 used engine runs rough, 0-5 % leakdown, 135 pounds compression, new plugs, wires, crank sensor, will not idle runs very rich. Just swapped engine out, cat is clear, removed plugged muffler.
Old 05-25-2005, 11:38 PM
deadBird's Avatar
deadBird deadBird is offline
Re: 92 Cavalier 2.2
Replace fuel filter. Run some 'SeaFoam' through it. Also, possibly check coil packs. If it doesn't idle well, disassemble the IAC (Idle Air Control) valve and clean it along with the throttle body.
