Old 05-22-2005, 04:30 PM
tia333 tia333 is offline
Angry 92 Gp Le 3.1
Where are the Idle air control valve and crank shaft position sensors located. and how do I replace them.
Old 05-23-2005, 05:37 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 92 Gp Le 3.1
The idle air control motor and valve are located on the side of the throttle body. The crank position sensor is located on the side of the engine.
I do not suggest that you change the CPS yourself as you must perform a case learn procedure once it is changed. The IAC motor unbolts with a couple of screws from the side of the throttle body and can be easily replaced in just a few minutes.
