Old 05-22-2005, 04:19 PM
steener steener is offline
AC recharge
Alright, Ive got a can of 134 and the hose for my 97 Blazer. Can I do this myself or is it very complecated? Can I just refill it. The AC was working fine. Now the compressor just kicks in every 10 seconds or so and then kicks out. Ive searched the forums and it seems I may need a guage. Any help is greatly appreciated.
Old 05-22-2005, 04:27 PM
Oh and how long should it take to put a can of 134 into the system?
Old 05-24-2005, 06:20 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: AC recharge
Get a gauge to measure the level of the fluid in the system.
Get a measure and charge bottle from Autozone.
It is made by Interdynamics.
It has the right oil and refrigerant mixture to refill the system plus a gauge to measure the level.
You test the pressure with a gauge with the AC on MAX and the fan on full blast.
Use a gauge or don't do it at all.
You overfill, you will destroy the system.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-25-2005, 05:42 AM
ricksza's Avatar
ricksza ricksza is offline
Re: AC recharge
Without a gauge, you will have no idea of what pressure the system is producing. I have personally seen the small cans expand because of a stuck valve in the system. It was putting out over 300psi before it broke the gauge.
Old 05-25-2005, 08:09 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: AC recharge
I've used the ones BlazerLT is talking about. Walmart sells them. too.
Old 05-25-2005, 08:30 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Re: Re: AC recharge
Are those the ones that have the R134a in them with a gauge on the line ?
How do you know what the PSI SHOULD be for say a 99 ? Are they all the same ?
Do you put it on the left port (near firewall) on evaporator ???
I have "ok" cooling but am wondering if it could be better as it's 6-7 years old.....?
Any observations / tips are appreciated...
thanks
T
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 05-25-2005, 09:08 AM
blazee's Avatar
Problem?
Re: Re: Re: AC recharge
thanks
T
Yes they are the ones with 134a and a gauge in the line. Here's a link to a description at Advance Auto, they are cheaper at Walmart, though.
http://www.partsamerica.com/ProductD...tnumber=MAC134
Here are the instructions:
http://www.partsamerica.com/product_...structions.pdf
The low side port is on the acumulator.
I don't know what the PSI should be I just went with what the can said, according to it:
0-25 PSI......Add refrigerant
25-45 PSI....System has proper amount of refrigerant
45-65 PSI....Do not add refrigerant! Seek professional help!
65-200 PSI...Do not add refrigerant! Your system has a problem other than low refrigerant. Seek professional help!
Old 05-25-2005, 09:22 AM
TonyMazz's Avatar
Re: Re: Re: Re: AC recharge
Whoops I meant accumulator...the evaporator is in the firewall box right ?
Thanks....
Old 05-25-2005, 09:32 AM
blazee's Avatar
Problem?
Re: Re: Re: Re: Re: AC recharge
Thanks....
Yes, the evaporator is in the firewall box. And the condensor is by the radiator.
You're welcome.
Old 05-25-2005, 04:46 PM
Thanks guys for the info. Ill see if I can get the "Measure and Charge" at Autozone.
Old 05-25-2005, 04:57 PM
Re: AC recharge
Scratch that idea. Called Autozone and itseems I need a license to purchase coolant in WI. Is there a distributor online that I could purchase from? I refuse to pay shop prices for someone else to do it for me.
Old 05-26-2005, 01:31 PM
TonyMazz's Avatar
Re: Re: AC recharge
Thanks for the tip as I too live in WI...so on my way to work (in MN) I picked up a bottle no questions asked...
Old 05-26-2005, 04:43 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: AC recharge
I got that exact autozone coolant hose.
I wont get into the details, but the shop wanted $950 to replace everything in my ac system. $4 of JB Weld has done the trick for now...
Old 05-26-2005, 04:47 PM
blazee's Avatar
Problem?
Re: Re: AC recharge
leaking compressor body?
Old 05-26-2005, 04:52 PM
chcknugget's Avatar
exactly.
