Old 05-22-2005, 01:33 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
Sorry to bug you guys, but...
i've made a couple of post and they have just been a combination of problems!
well here are the symptoms:
when im going 30-40 and i let off the gas all the way the RPMs drop to 500, and when i deaccelerate fast it drops to 250 and then dies sometimes!
also this morning i drove it a little while, the mph gauge, trip milage and total milage worked just fine!! then my car died turning a corner! then the MPH gauge, trip milage and the total milage didnt work anymore! well i took off my air box so i can look at the throttle body and it wasnt stuck closed but when it was starting, some smoke came out the intake! to me this sounds like a serious problem. could someone help me!
thanks!
Old 05-22-2005, 04:21 PM
Re: Sorry to bug you guys, but...
oh i forgot to add:
my fan stays on all the time now!
also some son of a bitches i think put salt in my gas tank! i found a little bit of salt kinda puddled up in the nose peice of the tank where u put gas in.
what kinda shit am i looking at?
Old 05-22-2005, 06:10 PM
come on guys!!
am i fucked or what/
Old 05-22-2005, 07:07 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
probably
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-22-2005, 07:15 PM
Morley Morley is offline
Salt or sugar? If you have a fuel filter in place you should be fine. Fans on all the time is bad..pull codes from the computer, see what it says.
If you suspect someone put something in your tank, drop the tank, drain it and pull the sending unit, remove the pump. If the sock filter is still on the pump, get a new one and replace it. Clean out the inside of the tank real good. Put the sender/pump back in the tank and reinstall the tank and change the fuel filter.
Get a locking gas cap.
Old 05-22-2005, 08:25 PM
well i tried to run for codes. and nothing came up.
Old 05-22-2005, 08:52 PM
Re: Re: Sorry to bug you guys, but...
Nothing? As in not even code 12? If that is the case...get a new ECM.
Other things to check. Do you have spark? Pull a plug wire and stick an old plug in it and touch the tip to the engine while someone cranks it..is there a spark? Is it a nice bright blue/white? No spark, most likely an ignition module...weak looking spark, most likely a coil or very bad wires or cap/rotor.
Old 05-23-2005, 02:12 PM
LT1MAN LT1MAN is offline
Banned
holy crap, sounds like some problems. maybe a vacuum problem, im not too sure about your motor tho.
Old 05-24-2005, 06:09 PM
scratch the salt. it was suger, i think im screwed!!!
Old 05-24-2005, 06:10 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Call some mechanics see if you can replace the fuel pump & fuel filter and drain your tank to see if it will fix it and hopefully not damage your engine badly. Have you made any enemies lately? and file a police report!
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 05-24-2005, 06:21 PM
i havent had any enemy's lately but whoever did this, their car is gonna taste my gat!
jk, but i'll sue their ass
Old 05-24-2005, 08:41 PM
With the fuel pump sock strainer and the fuel filter in place nothing had a chance to get to your engine. may want to replace the pump while you are at it, cost about $50.
contact your insurance co and the police.
Old 05-24-2005, 11:17 PM
well the fuel pump was new it had about 60 miles on it so the filter on it was prty new. i hope to god it didnt get in my block. pls pray for me!!!
Old 05-24-2005, 11:37 PM
jd87sep jd87sep is offline
Send a message via AIM to jd87sep
i guess someone did a taste test...
Old 05-24-2005, 11:49 PM
ya it wasnt fun...
