Old 05-22-2005, 12:05 PM
sixfeetunder sixfeetunder is offline
Unhappy Windstar POSSESSED with failure
I have 1996 windstar , I know its older but its all I have,, first my front dome lamps will not go on anymore,but the one in the back passanger seat behind driver will , In Febuary in Ontario our heater blower motor just stop working , I replaced it thinking it was gone still will not work but we had duel motor one in the back when the car got going the back blower heated the van , now my windows (power) fuse #34 driver side just stoped working it will not go up at all after it went down (I hopw will nt rain) and the passanger window will not go down fuse #40 ,now my dimn lights just are not working that was the only way to get the front dome lights on and when I use the auto door locks on the key chain my lights stay on when I use th lock button any help Please .............
Old 05-22-2005, 01:16 PM
CoachKarl CoachKarl is offline
Re: Windstar POSSESSED with failure
Hello Sixftunder,
Golly! Where's your sense of adventure. What you have here is a challange. Something to look forward to fixing. If it were me, I'd do the stuck down windows first. Undo the two screws at the bottom of the door liner, the screw behind the release handle, and (gently) push up on that big piece of plastic. Unplug all the electrical stuff, (keep the window button hooked up), pull back on the moisture shield (gently), and rap (gently) on that window motor with a hammer handle until it starts working. Saturate it with oil, then, as you work it up and down, note all the joints that you can lubricate, and do it. (Watch your fingers) Next start banging (gently) on that door lock thing. If it's stripped, go buy a new one and replace it. While your at it, replace the shot door speakers too.
Karl
Old 05-29-2005, 04:22 PM
mb8353 mb8353 is offline
If you have had someone else work on your vehicle, check all of the fuses to insure that they have not been switched around. you will need your owner's manual to see what amperage of fuse goes in each circuit.
hope that helps!
