Old 05-22-2005, 04:08 AM
JustinCredible10 JustinCredible10 is offline
Engine starts but dies immediately. Help!
Hi all,
Here's the scenario: I worked on installing some subs into my car for a few hours today. Most of the time the negative was disconnected from the battery but for a while the car was in the "acc" position (dome light on, radio on, etc). After I was finished installing I tried to start the car and it started normal but died 2-3 seconds after starting. I tried again and it tried to turn over but wouldn't start. I replaced the battery but it still dies after a couple seconds. Does anyone have any idea what the problem could be? It's a 98 2.2L with 120,000 miles. Thanks for the help.
Justin
Old 05-22-2005, 04:17 AM
I should add that I tried jumpstarting it as well but still...start and died after a few seconds.
Old 05-22-2005, 07:36 AM
public's Avatar
public public is offline
Re: Engine starts but dies immediately. Help!
Bad ignition switch?
Check to see if it is losing fuel or spark. Most likely it is one or the other and that will give you a direction to go.
Yes, I am retarded.
Old 05-22-2005, 06:00 PM
Nitrous_Boy Nitrous_Boy is offline
Banned
Send a message via Yahoo to Nitrous_Boy
so it worked fine before you added the subs??
Old 05-22-2005, 09:07 PM
Well yeah, but the subs aren't hooked up at all right now. I actually couldn't get them working so I just disconnected them. No connection to the battery at all.
Old 05-24-2005, 04:10 PM
Banned
did you wire it up right or did you fry something. i am trying to figure out if you have messed up your computer or alternator.
Old 05-24-2005, 06:16 PM
Ryan066 Ryan066 is offline
check for fuel and spark and let us know.
sounds like a dead fuel pump
Old 05-24-2005, 08:08 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
while leaving the power on, and playing around with the wires, sounds like you got a dead fuel pump, at least that what it seems like.
