Old 05-21-2005, 11:26 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
DSMlink experance is needed
i just logged my first run on dsmlink V2
mods in sig
stock fuel
stock exhaust
MBC@ 9-10 psi
MAF un-Hacked
click below to download log:
http://www.dsmlink.com/forums/attach...achmentid=2228
Thanks,
Jake
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 05-22-2005, 01:02 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: DSMlink experance is needed
The log looks pretty good. However, I'm thinking it's because you're being such a pussie and running extremely low boost Seriously, start turning the boost up a little at a time until it reaches 14-15psi. If you're still not knocking, take a little bit of fuel away. Stock 1g timing curve is fairly aggressive, so I'd leave it alone for now. Get that stock exhaust out of there! A fuel pump would be good too.
Idle airflow seems a tiny bit high, but it's probably because you need to adjust your BISS like you said - your idle is set at 800 but it's actually idleing at ~950.
Overall, the log looks good (for low boost, of course )
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 05-22-2005, 07:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
Unless I missed something this should be for a 2g? The car in the sig is a 95, and the term "V2" should only apply to 2g DSMlink, since the 1g version is on its first revision, unless the client being the same for both types gives people the impression its v2. At any rate, I'm going to assume 2g.
Idle airflow is very close to the "correct" .27 grams per rev, which is good.
Timing is on the stock curve, but it is high because the airflow per rev drops to 1.3 by the end of the gear. Remeber that 2.1 is the threshold for the highest load maps, which results in the typical 16-17 degree max timing level. 23 is awefully high, but at such low airflow, the mitsu engineers deemed it safe and appropriate. More boost will take care of this ;o) 1g maps are actually a little less aggressive, since timing gets pulled back out over 6500 rpm or so! I think they may just be more agressive when you lower the airflow signal with an AFC or similar, which results in the huge timing numbers 1gs see, but this is just speculation. I havent seen the actual changes with airflow/rev anywhere.
There was a little wheelsping and then a bog on the launch. Doesnt matter, just thought I'd mention it.
There is a pretty good misfire in first gear, you can easily see it in AFR and front O2, and IOT and IDC (injector on time, and ijector duty cycle). Usually ignition related, plugs and/or wires. What gap are you running? The rich mixture could have just bollixed the plugs on the stutter box, since it was only a problem in first gear and the others look fine. Pretty common. But I would still shoot for about a 028 gap if you're not there already.
I like the fact that these logs go right to 7k. So may poeple post logs that are just half of the information. Thats about it for the current log.
About the future, like geek said, time for more boost! I would lean out now at low boost to 11:1. On stock fuel, and stock MAS (which has all indications of reading correctly) you can place reasonable trust in the DSMlink AFR calculation there. Old AFR divded by New AFR, minus 1, will give you the percentage change for your WOT sliders in the fuel table. 10/11-1, 9% will do it. Leave timing stock (zeroed). Start to raise boost a couple psi at a time watching for knock. At this low airflow level you could probably run over 12:1 and not hurt the motor, but its good practice.
A 14b should just fit inside the stock injectors limitations if you keep AFR at 11:1. At stock AFR it may run out of IDC sooner than the 30 lb limit. The stock pump on a 2g is pretty good, just be sure it is rewired. That changes everything. It will cover a 14Bs output, but again, watch the logs. Under "Dash" set your knock CEL for 3 degrees perhaps to be safe. 5 can be a little high. Fuel system upgrades are always a good idea though, so if you had any in mind, feel free.
If you want to figure out the Idle speed thing, log ISC Position and Learned Idle Adjust. In fact you are only captureing a few values, you could probably add mid and lo trims as well if you wanted to get into that stuff, but with stock fueling and MAS, you shouldnt have any changes to make. SOmetimes it can point out vac leaks and other small problems though...
Badass. We need more DSMlink logs on here.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-22-2005, 10:57 PM
97_3clipse's Avatar
ok well i turned up the boost too 15psi today and watched for knock with the stock boost gauge set as a knock gauge...very little ,if any.... went to a swap meet today so i didnt have time to log.
Be sure tommorow night to see a log posted in here.
im gonna log it at defaut settings with 15psi of boost ,as a baseline.
...and yes i have a 2g with a 6 bolt...
Old 05-23-2005, 10:20 PM
97_3clipse's Avatar
ok took two logs tonight....both at 15psi
first log was run at default setting at 15psi
http://www.dsmlink.com/forums/attach...achmentid=2241
the second log is -%5 fuel across the board(global) recommened by a dsmlink forums member....
http://www.dsmlink.com/forums/attach...achmentid=2242
all i messed with was fuel .....think i gotta pull sume timing in high RPMs
enjoy
Old 05-24-2005, 07:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I wanna see the logs too........
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-24-2005, 08:25 AM
AF - Advisor
Just go to www.dsmlink.com, download page, and make it happen
The reason you see the knock at the top of the gear in the second log is the target timing is quite high. Its shooting for well over 20 degrees, as much as 24 by 7300 rpm. Too much. The reason the timing is so high is because the airflow is so low. Below 2.1 g/rev, the ecu considers it safe to run a leaner AFR and more timing advance If you increased boost so that airflow was over 2.1, timing would be back down to 16-17 degrees, and you would most likely have no knock.
Your injector duty is quite low, 75%. So you can afford more boost at least as far as injectors go. The stock pump on the 2g is pretty robust too, and matches the 450s well. Doing the math (24 lbs/min times 1.25 (to add the 25% headroom you have in IDC) gives me 30 lbs/min. Funny how the math always works. At 30 lbs/min on my setup I am at exactly 100% IDC That will get you over the 2.1 g/rev hump for the vast majority of each gear, and if it dips below, its so close the change applied to timing and AFR is minimal.
Something in our setups is causing a difference in the airflow:boost ratio however. At 15 psi, my car is at 30 lbs/min. Relevant mods that come to mind, external gate (makes exhaust act like a larger exhaust), full 2.25" hard pipes, KN fipk filter kit. Should be it. You might need a good 17-18 psi to hit 30 lbs if all goes well. As long as you dont go over 100% IDC, and more importantly dont knock (going over 100% isnt bad if you still end up around 11:1, etc), you will be fine. Keep an ey on timing, I would keep it down around 16-17. If you decide to keep boost at this level, then pull out the appropriate amound of timing from the sliders to emulate the stock curve (see dsmlink tuning guide, it shows the whole stock curve over 2.1, so you can more easily emulate it. Just see what timing is at each rpm point (when there is no knock) and pull out the difference between that and what it should be). Remember that your timing advance equals target timing set by the load map you are on (which is based on g/rev airflow) minus knock retard, and plus/minus anything on the sliders, at that particular rpm.
But to keep from getting overly complicated, I would recomend putting that 5% fuel back in, and start raising boost shooting for airflow in the high 20s, or as close to 30 as you feel comfortable going. Timing should max out around 16-17, and from this point start your fuel tuning, ultimately aiming for a AFR of 11:1 if you trust that your air metering is acurate (no boost leaks, unhacked mas, etc) and your fuel flow is accurate (injectors flow what they are rated at, you have the right data entered in options>car, and fuel pressure is correct at all boost levels).
Kevin Jewer
Old 05-24-2005, 08:51 AM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
i got you have to have a username and that stuff to get to DSMlink
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-24-2005, 10:06 AM
Re: Re: DSMlink experance is needed
When I try to register I get the following message:
Sorry, registration has been disabled by the administrator.
1997 Spyder GS-T
5-Speed
Old 05-24-2005, 10:32 AM
Gsx_hooptie Gsx_hooptie is offline
OTish: Registration is restricted to guys who own the product. Kinda sucks, because I'd like to learn to tune before I get the program, that way I'm not wasting time once I get it and not knowing what to do with it.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 05-24-2005, 11:54 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
you can email the staff and ask for a read only permissin to acess their fourms. just as i have done.
DSM geek
Old 05-24-2005, 04:30 PM
AF - Advisor
I wouldnt asvise people to ask for membership unless they are serious about buying it. Otherwise we end up with a thousand and one fucksticks polluting the last really good forum.
I was under the impression that you wanted to see the logs, in which case you need to download the program, not register for the forums. The software is a free download for anyone to check out, fully functional. In fact, if i lose my DSMlink software for whatever reasons, thats where I get it back. The latest client may not be there, but you dont need full functionality to see logs.
Kevin Jewer
Old 05-25-2005, 06:51 AM
Hey, I'm not a fuckstick
Right, but the problem is that 97 3clipse linked to the logs that he posted in the forum. So I would need access to the forum either way.
1997 Spyder GS-T
5-Speed
Old 05-25-2005, 11:59 AM
AF - Advisor
I dont get any login page or anything when I click on the links. Did you try to save them?
Kevin Jewer
Old 05-25-2005, 12:05 PM
For the software, click on the "Downloads" page, click on the appropriate link. The first one, "Full install, v2.5" worked for me.
As for fucksticks, I think the people on this forum who are interested in dsmlink are aright
Edit>> Again, though, we can't see the log in question.
