Old 05-21-2005, 09:09 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
How do you remove the fuel pump??
I think i figured out my problem and i need to figure out how to remove the fuel pump. Is there any way i can skip droping the tank?
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-21-2005, 09:13 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: How do you remove the fuel pump??
nope.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-21-2005, 09:28 PM
how do you do it then by taking out the tank?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-21-2005, 09:32 PM
Kven's Avatar
Kven Kven is offline
you dont need to drop the tank...just take out the back seat(if you have one).
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 05-21-2005, 11:23 PM
EF You's Avatar
EF Life Giver
Re: Re: How do you remove the fuel pump??
that panel only accesses the fuel level sensor. the pump is in a different part of the tank
Old 05-22-2005, 12:12 AM
Kven's Avatar
Re: Re: Re: How do you remove the fuel pump??
No you pull out this thing that has the fuel pump connected to it. ill look for a pic.
1988 Honda CRX DX
Old 05-22-2005, 12:13 AM
Kven's Avatar
found a full how-to: http://www.c-speedracing.com/howto/f...p/fuelpump.php
1988 Honda CRX DX
Old 05-22-2005, 12:37 AM
EF You's Avatar
EF Life Giver
thats not an EF. thats an EG
Old 05-22-2005, 12:42 AM
Kven's Avatar
the EF should be the same, if you want me to ill open mine up and take a look(my CRX is stripped right now)
1988 Honda CRX DX
Old 05-22-2005, 07:54 AM
EF You's Avatar
EF Life Giver
you can, but every EF ive owned has been the same. the fuel level sensor is under the backseat, and the fuel pump unit is on the far driver side of the fuel tank.
you dont even have to take it out, just go look at the access panel. if it doesnt have two hoses and a wire hooked up to it, then the fuel pump isnt there. if its just a single wire, then its just the level sensor.
Old 05-22-2005, 06:16 PM
Kven's Avatar
yea youre right, i just took a look and the fuel pump is farther back.
i guess you will have to be dropping the fuel tank.
1988 Honda CRX DX
Old 05-23-2005, 12:33 AM
damn, does any one have a website with instructions on how to do this?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-23-2005, 03:18 AM
Kven's Avatar
i have some pics from the helms manual but its too big for the gallery, i can email it to you if you like (theyre like 130k each, 2 pics)
1988 Honda CRX DX
