Old 05-21-2005, 08:46 PM
SComp23 SComp23 is offline
Leaking Pumpkin
Alright so it appears that fluid is leaking out of the bottom of my pumpkin, I am guessing it is just a gasket. How much should this cost to fix, and is this a huge problem? Thanks a lot! By the way it is a 1998 LS 2x4
Old 05-22-2005, 05:04 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Leaking Pumpkin
Do it yourself... Put a drain pan under the pumpkin. Pull the cover (13mm bolts) Spray out liberally with brake clean (1 can should do it)
Scrape EVERY LAST SINGLE BIT of the old gasket off the rear and the cover itself. Install in reverse. Hand torque in a cross hatch pattern from the middle out. Fill pumpkin.
Cost- Gasket 7.00
Gear oil (80/90) 2 bottles 8.00
Old 05-22-2005, 02:12 PM
Wow that was surprisingly painless, one last question though, what size tool do I use to get the drain hole open for the pumpkin? Thanks a lot!
Old 05-22-2005, 02:17 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Leaking Pumpkin
You should be able to use a 3/8 drive rachet and an extension. The extension will fit in the square hole.
Old 05-22-2005, 04:11 PM
rlith's Avatar
Re: Leaking Pumpkin
Sometimes they don't, the best thing to do is use a snap-on pipe socket..(available on their site for about 9 bux) That's not really a 3/8 hole, it's slightly smaller.
Old 05-22-2005, 04:45 PM
Re: Leaking Pumpkin
Thanks so much for all of your help guys, it was really a nice project to fill my afternoon and I had a good time doing it. Got dirty as hell but hey, thats what Gojo is for! I think I probably saved myself a lot of money by doing it myself, the gasket was only $3.48!
Old 05-22-2005, 04:51 PM
rlith's Avatar
Re: Leaking Pumpkin
Glad we could help. The worst part for me anytime I have to do one of these is scraping the damn cover to get the old gasket off...(hate that)..
