fan problem
the only time my fan come's on is when the AC is on. this would cause overheating while im driving at 20-30. but when i got about 40-50 it cools down. but when its really hot outside (like 80-100) it dosnt cool down till i go about 50-60. could someone help me on this.
thanks! |
Re: fan problem
camaros are designed to run hot. the fan should come on at around 210 degrees F.
![]() Quote:
Re: fan problem
but it gets to about 220, and untill recently it got up to about 230. which i dont think thats normal.
Re: fan problem
yah mine gets around 150-160 on a average day sometime she'll get real hot but then cools right down. Some ppl get cooler themstates to keep um cool. Its a fairly cheap part.
Re: fan problem
your fan switch thing that's screwed into the engine block is bad. replace that and you should be fine.
Re: fan problem
Yeah sounds like you need to replace the coolant sensor. The ecm controls fan. Should come on around 215. The coolant sensor is near the T-stat housing.
Re: Re: fan problem
It's normal,the fan will come on. I had a mechanic check it out and he said it's normal. GM just wanted to run these cars hot. Try making an cold air intake, That will help some. That's what I did.
91 RS Camaro V8 305 TBI cold/ram 14"/3" open element K/N filter 3.73's B&M Megashifter 180 thermostat Flowtech TERMINATOR Exhaust 3" exhaust cutout Silvania Silverstar Headlights Ronal R15 Firehawk Wheels Hankook Ventus Sport (front) Sumitomo HTR+ (rear) 275/40ZR 17 all around... _____________________________ |
