Old 05-21-2005, 06:29 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Exclamation HELP..filling transmission.
I read pervious posts about this issue but I'm not quite sure what to do. I drained the oil before I could get the filler bolt off (17mm) and now I cannot get the filler bolt off for the life of me and I think it managed to strip the bolt a bit so now I need to fill from somewhere else, someone said the reverse switch, but there is some kind of rubber boot on it and I can't seem to get it off...can someone help me!!!
Old 05-22-2005, 12:46 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: HELP..filling transmission.
the rubber boot covers the wire part of the sensor. if you look down at the base of the sensor, its hex shaped. use a big wrench on it, i think its 19mm.
you are also gonna have to be really careful about filling from there so you dont overfill. the reason the fill plug is where its at is because thats the level that the trans need to be filled at. if you overfill it, the gears are gonna be submerged in oil and its gonna either foam up the oil, or just make the trans run sluggish. i would look up the factory fill amount and only put that much in it.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-22-2005, 12:56 AM
BullShifter's Avatar
Re: Re: HELP..filling transmission.
That's a perfect example of why you should remove the fill before the drain.
1.9qts
Old 05-22-2005, 07:40 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
you can also use the speed sensor hole to fill it, that is what I usualy use. pulling the speed sensor you just need a 10mm socket and it's easy to get to.
GL
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 05-22-2005, 07:50 AM
EF You's Avatar
EF Life Giver
be careful with the speed sensor. the gear on some of them is made of plastic. you definitely dont want to break the gear off and have it fall into the differential.
Old 05-22-2005, 03:37 PM
clawhammer's Avatar
clawhammer clawhammer is offline
I'm thinking of doing this on my CRX Si also. Basically I just need to look for the fill nut, undo that, then drain it (what size nut??) and then put 1.9 qts of Syncromesh. Is this correct?
2001 Honda S2000 New Formula Red
Mods:
Engine: Comptech Air Intake Box, miscellanous chrome dress up pieces
Suspension: Comptech front strut tower bar
Exterior: Grillcraft grill, lots of wax
Interior: Rick's leather console cover, Muz one-piece luxury floormats, Rick's windscreen,
Electronics/Audio: Polk speakers
Wheels/tires: 18" SSR Competition wheels with 225/40 and 255/35 tires
Old 05-22-2005, 05:24 PM
thanks for the help, I filled it through the drain hole with a liquid pump..1.9Qts.
Old 05-22-2005, 11:37 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
I just did a swap today in my car (91 CRX Si)... It didnt have a bolt at all... It was just a square hole where a 3/8" ratchet went... It even says that in the Helms...R U sure your taking off the right thing?? It should be behind the splash sheild on the passenger side...
Old 05-23-2005, 01:04 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Exactly what I did last summer!
That's the only way I could think of.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 05-23-2005, 01:24 AM
The fill plug is a 17mm bolt and the drain is 3/8" square plug.
Old 05-24-2005, 05:39 PM
krustindumm's Avatar
krustindumm krustindumm is offline
Reverse switch is the fastest way.
What everyone calls the *fill hole* is actually a fill check hole. Fill it till it runs out there, then stop and plug it all back up.
91 Civic Dx Hatch
Midwest Honda's MySpace group
