Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-21-2005, 03:48 PM
Tacuvito Tacuvito is offline
Question A/c Blower Stopped
95 SL 1.9 Liter 134,866 manual transmission. This morning I started my car, no problems. I let the engine warm up and since I live in Texas I turned on the A/C. I drove to the gas station and turned off the car.
When I started the car again the A/C blower stopped working along with the cooling fan. The "Service engine soon" sign came on. I just replaced the Fan Relay, Temperature sensor, and the thermostat. Here is the where it gets strange. I drove the car home and once there I was turning the ignition key, the blower and cooling fan began to work again. The service light also went out. I tried turnng off the car and back on a couple of time to see if it would happend again but it did not.The car ran fine. Hope anyone can help me with some ideas.
thanks
Tacuvito.
Old 05-22-2005, 12:18 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: A/c Blower Stopped
if it doesn't happen again, and everything works normal now, consider it a fluke. if it comes back, pull the codes using this method - http://www.differentracing.com/tech_...diag_info.html
Old 05-24-2005, 10:02 AM
I think it was my ignition switch. I might have short there. I went a used car dealer where they had another car and the ignition in that car did not feel as loose as mine. However I will try to get those codes. Thank you for you help.
Tacuvito
Old 05-24-2005, 07:53 PM
MassHokie MassHokie is offline
Re: Re: A/c Blower Stopped
Tacuvito
That's interesting......I have noticed over the past 6 months or so that my ignition switch has been looser also. In addition, I have had issues on 4 or 5 occasions getting the key in or out of the ignition. It doesn't really explain why braking caused the car to cut out (see my previous post) but it could be a contributing factor, I suppose.
