Old 05-21-2005, 02:54 PM
SlimJimRD SlimJimRD is offline
Unhappy 99 Electrical problem locks, seat, lights
99 windstar with 88,000 miles. Power locks do not work other than driver door, button on passenger will unlock driver door.
Power seat does not work.
Light out indicator is on. Right rear turn signal not working and indicator light inside blinks fast, bulb okay. Left brake and parking lights not working, bulbs okay. Front turn lights okay. Left turn indicator blink normally.
Have check fuses (okay) and cleaned all ground connections I could find but do not have a wiring diagram.
Any ideas???
Old 05-21-2005, 05:29 PM
12Ounce 12Ounce is offline
Re: 99 Electrical problem locks, seat, lights
Try fuse #13 in fuse box near driver's left foot. After that try "switched system power relay" #4 in same location. (Refer to owner's glovebox manual).
Old 05-21-2005, 05:51 PM
I replace fuse 13 and switched out relay 4 with both relays 1 and 2. This did not help.
I do not have 12 volts at fuse 13 which I think I should have. Also removed the fuse box and checked the orange/red wire in back and it does not have 12 volts. Will go out front and start checking those fuse 103 or 104
Old 05-21-2005, 09:16 PM
You are on the right track ... fuse #103.
Old 05-22-2005, 09:05 AM
Okay fixed the wiring of fuse 103 and now only have issue of power seat not working. I think it is a short as it worked yesterday after fixing 103 wiring but today after putting the van back together it is not working. Is there any easy way to isolate a short in the wiring?
Old 05-22-2005, 07:58 PM
If you are not blowing fuses, I would suspect an "open" instead of a "short".
Have you looked under seat to make sure connector is secure?
Old 05-23-2005, 09:37 AM
It is blowing the fuse.
Old 05-23-2005, 10:41 AM
fuse 122? ...104?
Try disconnecting the load (seat) ... and see if fuse continues to blow.
Old 05-24-2005, 03:30 PM
Disconnected the seat and fuse fine.
Unplugged all seat motors and hooked switch back up fuse fine
Plug in each motor and found that the front vertical motor will not turn much and doesn't sound good. Did not short out but no one was on the seat.
Is this motor worth taking apart to see what is the problem or just replace it. When I bypassed the fuse before the motor worked as I was able to raise it to the highest setting. Did I maybe go past some kind of limit on the seat/motor. Van gone for the rest of today so could not retry bypassing the fuse to see what happens with that motor.
Old 05-24-2005, 03:38 PM
Don't know. You're in territory I've never been.
Old 05-24-2005, 03:53 PM
Thanks for your help to date
Old 07-17-2010, 08:49 AM
I just fixed this problem last week. Finally found a seat track with motors at the junk yard, I assume the van was a cash for clunker. The dealer wanted like $800 vs $20 at the junk yard assuming you could find one.
I replaced the front motor and still had the fuse blow once in awhile.
Then I thought I should replace the seat contol switch. Of course I left the switch on the junk yard van. When back to the junk yard for some other stuff and the switch was gone, but I did find another one on a car that was the same.
Replaced the switch and no more issues.
If you read another of my threads you may have read the van engine seized up on me yesterday. But hope this may help someone in the future with their seat.
