Old 05-21-2005, 02:10 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Turbo/super charger ?s
Ok i've got a 91 305 Tpi camaro and not logn ago i rember seeing a single and twin tubo kit for my car. it wasn't a remot system either so does nebody know who else makes one? Or do u all think i could get better performance out of a supercharger for my application. Only mods so far are a K&N air filter and a flowmaster 80 series coming in soon. If i do either the tubo or supercharger will i need to get lower compression heads or will the stock one be ok for awhile? Thanks alot look foward to hearing your all opions.
Old 05-28-2005, 08:43 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Turbo/super charger ?s
Well if u put any one of them on a stock high mileage motor it will run like a bat out of hell for a day or so till it goes boom. So freshin up the motor first, and the stock heads will have a low compression ratio anyway so it will work but you won't get the most out of it with restrictive stock parts.
Old 05-28-2005, 11:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
turbo installs will require custom headers and exhaust, lots of complicated oiling issues, and valving for the wategate and blowoff valve. Vortec and paxton sell bolt on supercharger kits that will work just fine and offer 100hp boosts. If you run say, 5psi boost you should be fine, but dont be shocked if you run that on a stock engine with miles and you start seeing blue smoke. new bearings and piston rings are gonna be a smart fix.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
