Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-13-2002, 08:30 AM
Parts4Sale Parts4Sale is offline
Send a message via AIM to Parts4Sale
Post Many Parts For Sale 86-89 Acura Integra LS 2dr 1988
1988 Acura Integra LS 2 Door DOHC Parts For Sale
COMPLETE PARTS LIST AT: http://winbin.com/integraparts.htm
All parts came off a red 2 door hatchback with power sunroof, under 160k miles, 5 speed manual transmission.
Some may be original while others may have been replaced.
If you don't see the parts you need listed, please Email [email protected]
All parts are were in working order when removed from the vehicle, however all parts are sold AS IS with no warranty.
All prices do not include shipping. I am located near Hartford, Connecticut (CT).
I will consider delivering some parts in the greater Hartford area. No reasonable offers refused.
For Questions Or To Buy These Parts Please Contact Me By Email: [email protected]
If you need parts that are not listed please contact me. I have may minor parts, interior parts, etc.
Power Sunroof, Sunroof Motor, Track, Glass, Visor Complete
This is a complete power sunroof assembly. Glass is in good condition and has a smoke tint. This unit functioned well and is complete with the motor, track, and glass ready to install. It also contains a gray visor (part of the interior) that slides over the sunroof when not in use and trip around the sunroof the help secure and hold the headliner in place.
$200
Hood
Red paint. Very nice condition. Some minor stone chips, however paint is nice and glossy and appears to have no rust. Minor clearcoat damage. This part appears to have been installed during the rebuild of this vehicle at 94k miles.
$100/b.o.
Hood Hinges
Fair condition.
Drivers Side: $5
Passenger Side: $5
Pair: $10
Hood Latch
The locking mechanism for your hood. Fair condition, works fine.
$10
Computer Box
The computer box under the passenger seat. Minor surface rust on unit. Working.
$75
Front Bumper/Air Dam
This is the one piece front bumper/nose/front air dam. Red paint, black trim. Appears to be in fair condition. Some scratches, stone chips, etc. Front lower lip has crack on drivers side about 1.5" long. Easy fix with fiberglass.
$40
Instrument Cluster
Stock black factory Acura instrument cluster from a 5 speed manual, complete. With Tachometer, Speedometer with Trip Meter, Fuel Gauge, Temp Gauge, engine warning lights, all indicators. good condition, no cracks, speedometer unit has 150,450k on clock. Unit functioned fine up until mileage on speedometer. At that point the speedometer stopped working because I disconnected the speedometer cable in the engine bay during a repair job and was never able to get it working again. However, I believe the speedometer will function fine as long as you have the cable installed properly.
$50
Instrument Cluster Cover Pod - Black
This is the piece of the dashboard that covers the instrument cluster. Good condition. No cracks.
$15
Cam Shafts (pair) for 1.6L DOHC motor With Timing Gears
The condition of these cams cannot be guaranteed. Appear to be in fair condition.
$50
Headliner
Gray vinyl, good condition, one small indent, minor wear and tear, Has been cleaned up. For cars with sunroof.
$10
Rear View Mirror
This rear view mirror is in good condition and worked fine.
$10
Seats
Good condition, no tears on seating surfaces, drivers seat contains small burn mark. Drivers seat contains small tear approx. 1" on back vinyl.
Drivers $40
Passenger $40
Both $75
Headlight Assembly With Motor, Cover, Complete
Drivers side headlight appears to be in good condition with bright red paint, some stone chips, no rust, good condition. Passenger side has faded paint, and very minor rust forming on front lip, easy fix. Headlight assembly comes complete with headlight, bezel, metal skin, motor, etc.
Passenger Side $50
Drivers Side $60
Pair $105
Doors And Glass (Manual Windows) - Complete
Two Doors For 2 Door Hatchback Coupe. Red, paint faded, straight, no dents, minor wear and tear on edges, good over all condition. Passenger side has chipping on black edge molding around window and has minor surface rust but nothing major.
Drivers Side $150
Passenger Side $150
Pair $275
Windshield Wiper Motor
Worked fine.
$15
Radio
Factory Acura AM/FM/Cassette Radio. Wear on buttons, no cracks, good overall condition. Radio and tape deck seemed to work fine.
$30
Tail Lights
These tail lights are in fair condition. No cracks. Some slight surface wear and tear, does not effect functionality. Comes with all bulb sockets and nuts used to bolt to car.**
Left Hand - $35
Right Hand - $35
Pair (right and left) - $70
Front Bottom Fog/Parking/Blinker light assembly.
Left Hand - $10
Right Hand - $13
Pair (left and right) $20
Passenger side has chip on lens aprox. 3/4" by 1/4". May not pass vehicle safety inspection, however the the blinker still works fine and is visible with no breakage to the internal reflector. Some slight clouding/wear and tear. Overall condition fair.
14" Acura Alloy Wheels With Tires And Center Caps.
Good condition overall, one has small chip aprox. 1/4" on one of the spokes. Minor chips and wear and tear. Two good tires with lots of tread left, one has been professionally patched because of a nail hole but holds air without any problems. Other two tires are very bald, needs new 2 tires. Size 195/65-14" tires.
Set Of 4: $120
Battery
Penske, hardly used, brand new, only a few months old, cost $49.99, very good condition. Sticker on battery claims two year replacement guarantee by manufacturer.
$30
Power Steering Pump
Performed fine without any problems. It is believe to be original with 150k miles but I am not sure.
$30
Distributor
Performed fine without any problems. May be original with 150k miles but I am not sure.
$50
Valve Cover
Black Honda Motor Corporation DOHC Valve Cover. Black. May require new rubber spark plug well gaskets, however using a liquid gasket product during the install should ensure a good seal and not create any problems. Overall condition fair, some minor paint chipping, has been cleaned up fairly well.
$20
Side View Mirror - Drivers Side
Good condition, with plastic mounting plate to snap right into your existing mirror housing. For use on cars with lever-controlled mirrors (not power). Has small round blind spot mirror stuck to it. Passenger side also available (plastic mount, no glass mirror [got broken])
$10/b.o.
Air Box Assembly
Complete upper and lower. Good condition, no cracks, has writing on it in some sort of paint-like marker.
$10/b.o.
Upper Timing Belt Cover
Good condition, no cracks.
$10/b.o.
Factory Scissor Jack
Good condition.
$10/b.o.
Alternators (two)
Do Not Work, Probably Require A Rebuild.
Best Offer
Whole Car (minus the parts listed above)
You may purchase this car whole including the remaining engine parts, good transmission, body parts, etc...
Many good parts, good glass, sunroof, hatch, doors, etc.. This vehicle has a rebuild title and ran and drove, however the engine had a knock and possible leaky head gasket. It is not recommended you attempt to repair this vehicle for use. Body has bondo/fiberglass and had extensive rust around wheel rear wells, dents on both rear quarters. Brake Calipers, Steering Knuckles/Suspension components have been spray painted using flat black paint. Parts/Salvage value only.
Car w/ Parts Above (complete/taken apart) - $400/b.o.
Car Without Parts - $140/b.o.
:o :o :o :o :flash: :frog:
2003 Maxima GLE parts car... many parts for sale Hans_GZP Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 03-31-2008 04:44 PM
many parts for sale. integra, accord, civic bozos_si Classifieds 1 04-23-2006 03:21 PM
Many parts for sale for Jimmy/Blazer sdwenning Jimmy 9 12-05-2004 01:18 PM
1997 Probe GT for sale and many parts for sale also stings Probe 6 10-17-2004 02:13 PM
