Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-20-2005, 09:03 PM
Bear Bear is offline
Touring Suspension
Ah, Kids and cars. Grandson driving1993 GM home from work and the rear end settles on to the tires. Car is towed to a garage to await Monday inspection. I suspect that since the car has the self leveling suspension the compressor has failed or the lines to the shocks have failed. How hard to change the compressor and where is it located (kid has a Haynes manual). Also what is the possibility of changing out the rear shocks to some heavy duty Monroe/Gabriel/etc, is this an option worth pursuing? All inputs gratefully accepted as I will be doing the work.
Old 06-20-2005, 09:34 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Touring Suspension
I had the same set up on my '93 Crown Vic. I've heard that repairing the self-leveling suspension can be expensive. Don't know about the difficulty of the repair, but have heard that replacing the air bag suspension is $1800 for parts alone (don't quote me though).
Is the compressor still running when you turn the car on? If not, I'd try the easy fix: check the fuses for the suspension.
If all else fails, I would think that putting standard shocks on there would work; you'd also have to get the rear springs, as the bags replace them.
Good luck with it.....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-20-2005, 09:38 AM
alphalanos alphalanos is offline
yeah get rid of that complicated GM stuff. put some shocks and springs in it youll be happy with the results. and its alot cheaper.
96 EJ6. Future home of boosted B18C1.
Old 07-10-2005, 02:12 PM
reekor reekor is offline
Re: Re: Touring Suspension
Good luck with it.....[/quote]
The shocks are already there. Turn off your air ride (switch in the trunk) and disconnect the two wiring harnesses going to your air ride computer (in the trunk also, on most models it's mounted on the rear seat support on the driver's side and on some models right behind the air ride on/off switch). Simply pull the upper clip off the air springs (a coat hanger will do the trick) and pop the buttom of the air spring off of the axel with a flat screwdriver. remove the lower shock bolts so that the axel can drop a few more inches. Disconnect the air line/ power line connector from the air spring and tie it off to the car so that it does not flap around when driving. Pop in your coil springs (with upper rubber bushings) by hand or with a help of a crowbar ( watch the break lines so the you so not poke a hole in them). jackup the axel and attach the lower shock bolts. If you want to save on cash run to your local bone yard and get some spring there, 1988' to 1999 GM CV springs will fit, if you can find some from a interceptor or a taxi even better (never the car, the better).
Old 07-10-2005, 03:28 PM
Touring Suspension
Got her fixed, one blown air bag so I replaced both side air bags and also the dyrer.
